Headers???? - Mustang Evolution
Old 07-15-2013, 11:15 PM   #1
Yankee5.0's Avatar
Headers????
Witch headers r not that expensive n really good
Brand??
Power??
Torque???
Let me know thanks
Yankee5.0 is offline   Reply With Quote
Old 07-15-2013, 11:25 PM   #2
2013_DIB_GTCS's Avatar
Longtubes are the only way to go. Shorties aren't worth the money, and take the same amount of labor to install and give you approximately double the rwhp. Expect about 20 rwhp.
BBK and JBA will be your cheaper headers. Then probably Stainless works. ARH, Kooks, Borla and Bassani are more expensive headers.
As far as how good each brand is, that will be up to you to read reviews and figure out whats best for you
2013_DIB_GTCS is offline   Reply With Quote
Old 07-16-2013, 08:04 AM   #3
I have JBA and love them, gained 19rwhp just lt's alone
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 07-16-2013, 11:00 AM   #4
How was the fitment? Did you go x or h pipe?
Old 07-16-2013, 11:12 AM   #5
MidnightBlueGT's Avatar
Kooks is one of the best but expensive. Bbk is cheap yet still good quality.
08:25 AM
