2014 Base GT Passenger Seat Height? - Mustang Evolution
Old 07-17-2013, 05:45 PM   #1
elkk's Avatar
Is there any way/modification to adjust the 2014 Base GT Passenger Seat Height with manual seats?? Everyone feels like they are sitting in a hole. I sat there and I had the same impression. The drivers seat is higher than the passenger seat even in it's lowest position. Is it possible to add spacers or something between the seat mounting bolts and the floor pan?
Also posted on TMS
2014 GT / Ruby Red / MT82 / 3.73 / RR Sensing & Security
Mods: GT500 Axlebacks, Modest Pin Stripe, Side Scoops, Wheel Spinners, Lower Fog Lights, Strut Tower Brace, Chrome Shift Knob
elkk is offline   Reply With Quote
Old 07-17-2013, 05:53 PM   #2
anything is possible if you have enough cash....I just took my seats out and weighed them, I would say you would have to make new brackets but you could get longer bolts for the rear and try putting some washers or spacers in those, it may bring it up enought to make you happy, cant really do it on the front with out making a bracket, but the rears just sit flush on the floor pan, good luck
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 07-18-2013, 08:03 PM   #3
My wife complained about the same thing, that and the lack of a grab handle. I'd love to find a solution.
jasonc32amg is offline   Reply With Quote
Old 07-18-2013, 08:47 PM   #4
I am 6'2 so I feel like im too high, but like I said try putting some spacers under the seat bracket and maybe that will help out
Old 07-19-2013, 12:34 PM   #5
CorDog009's Avatar
Longer bolts with some washers under the seat? Cheap and easy.
'13 Deep Impact Blue GT, auto, BBK cat deletes, GT-500 A/B's, C&L tuned DiabloSport inTune, sound tube delete, BBK 85mm TB, JLT oil separator, NX plate kit.
CorDog009 is offline   Reply With Quote
11:36 AM
