Decreasing nvh - Mustang Evolution
Old 07-19-2013, 09:59 AM   #1
Decreasing nvh
As I replace things, I am starting to feel the effects of nvh. The worst is my upper strut mounts that are squeaking like crazy. I'm hoping to get that resolved soon. But I'm replacing my uca soon and I've picked up some nvh from my new lca's. so I've been researching dynamat to line my back seat and trunk to alleviate some of this nvh. Has anyone had success with this?
Mikeyt03 is offline   Reply With Quote
Old 07-19-2013, 10:04 AM   #2
Three things: Roush wheel-hop reduction. I had a BMR uca and I took that thing off within a week! Didn't like the noise! Roush kit is silent like a ninja
Old 07-19-2013, 10:06 AM   #3
I know but I don't know if it will correct my pinion angle. I have a 1.5 drop. What do you think?
Old 07-19-2013, 11:09 AM   #4
Oh man I don't know! I have the roush stage 2 suspension, and my drop settled to less than a inch. Mine was to the point where if it was ANY further it would need to be adjustable. So I lucked out. I refused to deal with the NVH, and I would have put the stock springs back in if I had to.
Old 07-19-2013, 05:37 PM   #5
blackbeast12's Avatar
Region: Delaware
A dss drive shaft like i got has the cv joint at the rear. it allows you to use the roush mount on a lowered car because pinion angle is of no concern with the dss drive shaft. I will be installing my d/s and my roush mount soon as my off road x pipe comes in! My steeda adjustable makes more noise then a busted chain saw...lol well not that much..
2016 Gt/Cs autowith 3:55', mbrp cat back and a n/a build on the way!...
blackbeast12 is offline   Reply With Quote
Old 07-19-2013, 05:45 PM   #6
Evil2014GT's Avatar
Ive had good success with dynamat. I put a bit under my center console around the shifter after i installed my barton 2-post bracket. Its quiter then stock. As far as the suspension goes im not sure. I have barely any increased NVH from my suspension work minus a liiiiiitle bit from my lcas and brackets at low speed with the windows up and radio off.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 07-19-2013, 05:51 PM   #7
Evil2014GT's Avatar
Napoleon85 posted this stuff in another thread. Its a Teflon based dry lubricant that will not pick up road grime, debris, or condensation. Seems to be a lot quiter then a regular lube for the bushings. I would give this stuff a shot and see if it helps. I know he was using spherical bushings which are traditionally much louder than poly bushings, and got great results.
http://www.liquidwrench.com/products/#!/5
10:16 AM
