Squeak in rear. - Mustang Evolution
Old 07-20-2013, 05:41 PM   #1
PISTONS8904's Avatar
Squeak in rear.
So I have a 2013 GT and I have this squeak on the rear end when I go over bumps or take a sharp turn fast... Dealership replaced the sway bar... And this dick head other dealership told me it wasn't the bushings and don't know what it is... Who else has the problem and please tell me you figured it out.
PISTONS8904 is offline   Reply With Quote
Old 07-20-2013, 07:06 PM   #2
I had the same problem 2 months ago but I have a great dealership, so I took it over to them and walla! Rear shocks replaced under warranty. So I gave them a 5 star satisfaction rating, which is a big deal to them.
Last week I had front LCAs squeaks, I took it over to them again and they already know the TSB about it so parts were ready for anybody coming for that TSB.
I have a 2013 Mustang GT also with little over 10K miles in odo .
Uncoolron is offline   Reply With Quote
Old 07-20-2013, 07:09 PM   #3
What are LCA's and TSB and I have 19 k miles on mine
Old 07-20-2013, 07:24 PM   #4
TSB 13-7-8. Squeaks in front suspension area while driving on bumps or rough roads, also it progress when car had been driving for a while.
Old 07-20-2013, 07:52 PM   #5
tc x 4's Avatar
Lower control arms, technical service bulletin.
Old 07-20-2013, 08:44 PM   #6
Am3gross's Avatar
My squeak was the exhaust hangers in the back, they were rubbing metal to metal, would do it once the car heated up to operating temp.... Then it was squawking like crazy
2013 ford mustang gt, black, bought 16th of August. Only mod so far is tinted windows.
Am3gross is offline   Reply With Quote
Old 07-20-2013, 08:55 PM   #7
I also heard about the exhaust hangars but mine has rubber around it plus they are tight. I really think it could be the shocks, haven't had anything up front yet maybe some noise from the exhaust which is a little annoying...
Old 07-20-2013, 09:00 PM   #8
Am3gross's Avatar
It only takes a little metal to rub to make the noise, I had less then 1/4 inch that was rubbing..
What u could do is get some wd40 and start spraying bushings one at a time till u find it, just make sure when you rule one out make sure you always spray that one when you go to the next. The wd40 won't last forever as it will get washed out.
Also you could always loosen all the bolts and get some white lithium grease and grease everything up.
Old 07-20-2013, 09:03 PM   #9
It's under warranty I want to take advantage of that.
Old 07-20-2013, 09:05 PM   #10
Am3gross's Avatar
I said the same thing, then they told me that since I had exhaust work done they would not cover it... Lol... They did however not charge me for the diagnostic so I am happy with them for now.
Old 07-20-2013, 09:58 PM   #11
I have exhaust work done too.... But what does that have to do with anything squeaking?
Old 07-21-2013, 07:13 AM   #12
Am3gross's Avatar
If when they redone the hangers they may have messed them up... Where it goes thru the rubber they actually squeezed the hanger together, causing it to rub against the metal that the hanger goes thru on the mount of the car.
12:13 PM
