So taking the cats off my stang today... - Mustang Evolution
Old 07-23-2013, 09:54 AM   #1
Mustang32Bill's Avatar
What's the best way to do it? I know there's some tricks!!
Mustang32Bill is offline   Reply With Quote
Old 07-23-2013, 11:34 AM   #2
FortyBrandon's Avatar
/\ illegal activity going on...
FortyBrandon is offline   Reply With Quote
Old 07-23-2013, 11:39 AM   #3
Venomouz831's Avatar
Are you gutting them or swapping midpipes?
)02 Gt, Founder of WE2G
Old 07-23-2013, 11:51 PM   #4
Ain't nuttin illegal until you get caught lol
---------- Post added at 12:51 AM ---------- Previous post was at 12:50 AM ----------
Swapping going magnaflow tru x
Old 07-24-2013, 01:58 PM   #5
Napoleon85's Avatar
Search for threads I started. There is a write up I posted almost two years ago ...
Old 07-24-2013, 05:16 PM   #6
CorDog009's Avatar
The top pass. side cat bolt is fun to get to, but other than that it's simple.
'13 Deep Impact Blue GT, auto, BBK cat deletes, GT-500 A/B's, C&L tuned DiabloSport inTune, sound tube delete, BBK 85mm TB, JLT oil separator, NX plate kit.
CorDog009 is offline   Reply With Quote
Old 07-24-2013, 06:00 PM   #7
Napoleon85's Avatar
Soak every bolt in penetrating lubricant an hour before starting. Otherwise, you're going to have a bad time.
Old 07-24-2013, 09:33 PM   #8
ddinn25's Avatar
Mine came rite off with no issues. But my car is only about 8 months old. The passenger side header/manifold to cat pipe bolt is a bit tricky. Had to use a 3ft extension with a swivel on the socket (15mm). I used the steeda cat delete pipes. Fit meant was perfect and the weld quality was absolutely perfect! There hand TIG welded! I also used a bit of permatex exhaust sealant around the flange that connects the delete/car pipes to the H pipe to help prevent leaks. Be really it didn't need it. They fit perfectly.
Oh and a lift makes life a lot easier. Did mine in less than an hour
2013 5.0 m6 base 3.31's tint 20in Shelby razors 255/35/20 falken fk 452's koni srt.t's sr springs j&m phb gt500 mounts upr rear billet lower ca's upr brackets upr adjustable upper ca flowmaster at classics steeda cat deletes airaid cai premium st brace jlt catch can MGW shifter and blk ball. Currently bama tuned 400hp 383tq. Zex blackout kit w/msd digital window switch, fpss, zex bottle heater, bottle opener, blow down, and purge with a dyno tune coming soon..
ddinn25 is offline   Reply With Quote
Old 07-25-2013, 08:13 AM   #9
The Blue Dragon
GrabberBlue5.0's Avatar
Just bumped napoleons ORX install up to the top
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 07-25-2013, 02:40 PM   #10
blackbeast12's Avatar
Region: Delaware
When i had my kooks super street shortys installed, my installer had a fit trying to get that 1 bolt out. Well finally got it out then took the liberty to set that bolt up so from now on you can get the bolt from the bottom. My offroad x will be in today or tomorrow . Cant wait to get it on and retuned accordingly!
2016 Gt/Cs autowith 3:55', mbrp cat back and a n/a build on the way!...
blackbeast12 is offline   Reply With Quote
11:06 AM
