Engine Codes 0420 and 0430 - Mustang Evolution
Old 07-23-2013, 10:05 PM   #1
tarupert's Avatar
Region: Nevada
I just had my JBA Ceramic Headers installed with a hi-flow cat x-pipe. On way home from shop everything was fine. Just took car out for another ride and was kind of hot-rodding around and check engine light came on with these two codes. Is this going to keep happening?
SCT Tuner, Vinyl Dipped Plenum and Valve Covers, BBK 85mm TB, JLT Oil Catch Can, Pypes Pipe-Bomb Axle Backs, JBA Ceramic Long Tube Headers, High Flow Cat X-Pipe, Forgestar F14 19x9, 19x10, Nitto Invo Tires, Eibach R2 Suspension, Eibach Adjustable Sway Bars Front and Rear, Eibach Adjustable LCA, BMR Rear Lower Control Arm Relocation Brackets, MMD Bolt-On Hood Strut, BMR Pan Hard Bar, Caster Camber Plates, Brembo Brakes, Adjustable UCA and Mount, Dynotech Aluminum Driveshaft, Procharger Stage II, Bosch 75lbs injectors.
tarupert is offline   Reply With Quote
Old 07-23-2013, 10:36 PM   #2
Until you tune it.
Mikeyt03 is offline   Reply With Quote
Old 07-23-2013, 10:56 PM   #3
tarupert's Avatar
Region: Nevada
Have Bama Tune on it now.
Old 07-23-2013, 11:01 PM   #4
acornsmoke's Avatar
revised tune for the headers/x-pipe?
acornsmoke is offline   Reply With Quote
Old 07-23-2013, 11:06 PM   #5
Are you getting the P90X code?
Old 07-24-2013, 12:16 AM   #6
tarupert's Avatar
Region: Nevada
Nope, just the two I mentioned.
Old 07-24-2013, 06:49 AM   #7
GE3G's Avatar
Lmao P90X
GE3G is offline   Reply With Quote
Old 07-24-2013, 10:31 AM   #8
MidnightBlueGT's Avatar
P90x code means your car is about to get ripped
Old 07-24-2013, 11:01 AM   #9
Old 07-24-2013, 11:48 AM   #10
Twisted 13's Avatar
ZLwhat. Bro what is the name of those heads with the funny sayings I've been trying to figure it out for a minute.
Twisted 13 is offline   Reply With Quote
Old 07-24-2013, 12:02 PM   #11
They are called MEME's bro! I have a app on my phone called rage faces that has all of them lol
Old 07-24-2013, 12:13 PM   #12
Ubnbit's Avatar
I'm not gonna lie, I read the p90x and I busted out laughing! Classic!
---------- Post added at 12:13 PM ---------- Previous post was at 12:12 PM ----------
There is a list of codes somewhere, just search it. I'm sure requesting a new tie will take care of them.
Old 07-24-2013, 01:42 PM   #13
tarupert's Avatar
Region: Nevada
Any specific tie? I have muffler tape and that didn't work, I have tried hitting the exhaust with my glass hammer and that didn't work either, I'm now drinking beer from my left handed mug trying to figure out if these two codes will keep coming back.
Old 07-24-2013, 04:09 PM   #14
Grabber Blue5.0's Avatar
You'll need to have your rear o2's turned off even though you have cats. Those cats are just too efficient. Hope you don't have to go through emissions.
Old 07-24-2013, 04:14 PM   #15
Mok
Will have fail emissions because the cats or because the LTs?
Mok is offline   Reply With Quote
Old 07-24-2013, 04:18 PM   #16
Neither. The tune. Once you turn those codes off the readiness test will fail you in most states.
Old 07-24-2013, 04:26 PM   #17
OrganDonor's Avatar
I have had JBA LT's and JBA catted X for about a year, no problems. Just get with Bama to revise the tune
2014 Shelby GT500...
OrganDonor is offline   Reply With Quote
Old 07-24-2013, 04:33 PM   #18
Your rear o2's are turned off.
Old 07-24-2013, 04:39 PM   #19
Mok
Even if your midpipe is catted?!
Old 07-24-2013, 05:32 PM   #20
YES!
Unless you're running say the Kooks green cats. Those will work.
Old 07-24-2013, 10:55 PM   #21
Mok
YES!
Thanks
Old 07-25-2013, 07:59 AM   #22
The Blue Dragon
GrabberBlue5.0's Avatar
OP did you ever get this resolved?
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 07-25-2013, 06:28 PM   #23
tarupert's Avatar
Region: Nevada
Problem fixed! YEA!
02:58 PM
