2013 check engine light - Mustang Evolution
Old 07-26-2013, 07:52 AM   #1
Has anyone had the check engine light start flashing and the ac cut off while accelerating hard?
tj145 is offline   Reply With Quote
Old 07-26-2013, 08:19 AM   #2
Gordito's Avatar
Hmm.. nope, only traction control..
Gordito is offline   Reply With Quote
Old 07-26-2013, 08:51 AM   #3
Evil2014GT's Avatar
Never had it happened to me, but i believe some cars are equipped to turn off the ac automatically when accelerating hard. Not sure if our cars are, but that could be it. As i was always told, its never a very good idea to drive the car hard with the AC on because of the extra load you put on the motor.
Im far from an expert on AC systems though , so hopefully somebody will correct me if i happen to be wrong.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 07-26-2013, 09:04 AM   #4
ddinn25's Avatar
Got any codes? My car would throw random cel's and had to have the o ring fix done on the cps. There a TSB for this issue. The A/C shutting off may just be coincidence?
My cel light would just flash and the car would miss fire and run like crap for about 10 seconds then start running fine. The cel would not stay on solid so fixing the issue was a pain! Had to leave the car running after the cel flashed to be able to get the codes
2013 5.0 m6 base 3.31's tint 20in Shelby razors 255/35/20 falken fk 452's koni srt.t's sr springs j&m phb gt500 mounts upr rear billet lower ca's upr brackets upr adjustable upper ca flowmaster at classics steeda cat deletes airaid cai premium st brace jlt catch can MGW shifter and blk ball. Currently bama tuned 400hp 383tq. Zex blackout kit w/msd digital window switch, fpss, zex bottle heater, bottle opener, blow down, and purge with a dyno tune coming soon..
ddinn25 is offline   Reply With Quote
Old 07-26-2013, 09:17 AM   #5
sleeperstatus's Avatar
I had the same problem with a couple different times and my ac never just shut off by it self
sleeperstatus is offline   Reply With Quote
Old 07-26-2013, 10:19 AM   #6
Will check for codes Monday. Just trying to keep from spending a day with a ford dealer.
Old 07-26-2013, 10:38 AM   #7
I have used the CarMD for the codes in my car and that seems to word pretty good and if you go to the dealership they should be able to give you a loaner if you wanted if they have to keep your car over night
Old 07-26-2013, 11:06 AM   #8
The Blue Dragon
GrabberBlue5.0's Avatar
Did your AC turn off or did It stop blowing cold air? AC systems have a high pressure shut off switch in them to protect the system from self destructing at high rpms. Basically the AC clutch pulley disengages at high rpms so your car will start blowing warm air
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 07-26-2013, 11:09 AM   #9
Evil2014GT's Avatar
Thanks for verifying. Thats what i thought, just didnt know the correct name for it haha.
Old 07-26-2013, 11:10 AM   #10
The Blue Dragon
No problem, my slave job is hvac service tech lol
Old 07-26-2013, 11:35 AM   #11
Evil2014GT's Avatar
Good money this time of year! Can you come look at mine? Haha (I get a forum discount right??)
Old 07-26-2013, 11:48 AM   #12
GE3G's Avatar
Im in the same trade... More refrigeration tho... What r hvac techs making an hour in the states if u dont mind me asking
GE3G is offline   Reply With Quote
Old 07-26-2013, 12:12 PM   #13
The Blue Dragon
The company I work for does a lot of residential, commercial, and refrigeration, as well as plenty of other stuff (but we specialize in hvac). I'm still pretty low level and I make $15 per hour but some of the guys I work with make $25-30 per hour. I also live in louisville, KY, elsewhere they probably make quite a bit more but their cost of living is also higher
Old 07-26-2013, 02:36 PM   #14
ddinn25's Avatar
I was going to go into that about 12 yrs ago. Went into industrial maintenance instead. I work on and repair cnc machines, assembly machine, and robots. Mechanical, electrical, Plc programming, cnc programming, ect. I work at a factory that makes brake calipers for just about ALL auto makes. We actually have the business for the new s550 mustang. (4 pot aluminum caliper)
Old 07-28-2013, 02:03 AM   #15
Mustang_96's Avatar
Wow I never knew is bad to have your ac on full blast when accelerating hard thanks for the info. I accelerate hard with ac on full blast and my ac just stops or blows warm air.
Mustang_96 is offline   Reply With Quote
07:51 AM
