Air box sound tube removal - Mustang Evolution
Old 07-26-2013, 10:52 PM   #1
I tried searching all over but couldn't find an answer for this. I know taking off the sound tube will make it loud in the cabin. If I only remove the tube from the airbox will it make the airbox louder? I don't want more noise in the cabin just trying a cheap way for a cai. Will it make it louder or should I just not waste my time?
Omgdudeidk is offline   Reply With Quote
Old 07-26-2013, 11:39 PM   #2
Loc: Austin,TX
You already have a CAI. If you dont want the sound tube you can pull it off and use some rubber grommets to seal up the hole in the air box and the firewall.
Old 07-26-2013, 11:41 PM   #3
I don't have a cai actually. Stock air box
Old 07-26-2013, 11:48 PM   #4
Loc: Austin,TX
What year GT,2011-14?
Old 07-27-2013, 12:48 AM   #5
Jsmorley81's Avatar
Your stock air box is a cai. From the factory. All the sound tube does is send noise into your cabin. If you delete it, it just deadens the sound of your motor to the inside of the cab. That's all
Jsmorley81 is offline   Reply With Quote
Old 07-27-2013, 01:06 AM   #6
Loc: Austin,TX
Exactamundo. As I said before,the car has a CAI already.
Old 07-27-2013, 01:48 AM   #7
ddinn25's Avatar
If you want it louder inside the car pull the sound tube loose from the fire wall and remove the wad of foam that's stuffed in the end
2013 5.0 m6 base 3.31's tint 20in Shelby razors 255/35/20 falken fk 452's koni srt.t's sr springs j&m phb gt500 mounts upr rear billet lower ca's upr brackets upr adjustable upper ca flowmaster at classics steeda cat deletes airaid cai premium st brace jlt catch can MGW shifter and blk ball. Currently bama tuned 400hp 383tq. Zex blackout kit w/msd digital window switch, fpss, zex bottle heater, bottle opener, blow down, and purge with a dyno tune coming soon..
ddinn25 is offline   Reply With Quote
Old 07-27-2013, 06:12 AM   #8
Loc: Austin,TX
Very true. Only problem is the OP stated he doesn't want the cabin noise. He's better off just pulling the sound tube.
Old 07-27-2013, 08:05 AM   #9
ddinn25's Avatar
I removed mine all together just recently. I already had the cai, cat deletes, and ab's on the car. The cai I have came with a rubber cap and hose clamp to block off the hole in the cai tube plus a plug for the fire wall. I'm not sure if its because my car is already pretty loud or if the factory sound tube didn't function correctly but there was NO noticeable difference of sound from inside the car with the sound tube off/deleted
Old 07-27-2013, 09:36 AM   #10
These are the stuff I used.
You find them at hardware store and parts store for the firewall plug.
Uncoolron is offline   Reply With Quote
Old 07-27-2013, 10:07 AM   #11
Here's what I used. Made for the job specifically and only a few pennies.
Ford Mustang Sound Pipe Delete Kit
Old 07-28-2013, 05:36 PM   #12
2013_DIB_GTCS's Avatar
$12 isn't bad at all. Might have to grab this kit. I've been wanting to get rid of the sound tube.
2013_DIB_GTCS is offline   Reply With Quote
Old 07-29-2013, 08:20 AM   #13
The kit also includes 2 firewall grommets. One solid and one with a wire pass-through you can use for gauges or whatever. Very handy.
Old 07-29-2013, 09:47 AM   #14
Alkhalil's Avatar
Thanks 5LHO for the tip. Clean and straight forward sound delete.
Alkhalil is offline   Reply With Quote
Old 07-30-2013, 02:18 PM   #15
BigBry0311's Avatar
DID this also here are part numbers
First up is the DORMAN MASTER CYLINDER GASKET part# 42098 purchased at Advanced Auto for under 7 BUCKS.
Second is HILLMAN ROUND CAP PLUGS 1 3/4" I believe this is the part# H#884315 This was purchased at Lowes in the hardware isle and was in the furniture parts drawer and comes 2 in a pack for 4 Bucks.
These parts fit great and I secured the intake elbow cap with a 1 5/8" - 2 1/4" hose clamp
Thanks to uncoolron for posting up the master cylinder gasket number.
BigBry0311 is offline   Reply With Quote
Old 07-30-2013, 06:01 PM   #16
I pulled mine off, and I don't think it got any louder in the cabin!
I think it actually got quieter!
~2013 Mustang GT
-Stock......for now!
http://www.youtube.com/user/StoneWhiteDaytona/videos
Fudge is offline   Reply With Quote
Old 07-30-2013, 06:08 PM   #17
You're welcome. For a cleaner look, I used a thin black zip tie for a cleaner look for the round cap plug and it never moved. I thought the hose clamp is an over kill and it's awful looking.
---------- Post added at 08:08 PM ---------- Previous post was at 08:04 PM ----------
Mine too got quieter. I pulled it out because of my Pypes AB drone around 1800 RPM and it helped.
Old 07-30-2013, 07:28 PM   #18
I pulled mine off, because it was useless, and looked dumb!!
But the Steeda CAI, is loud enough without the sound tube LOL!!!!
~2013 Mustang GT
Old 07-30-2013, 09:19 PM   #19
Wilhelm0075's Avatar
Region: Nevada
Thanks for the heads up. Just ordered one myself ::beer::
Wilhelm0075 is offline   Reply With Quote
Old 07-31-2013, 05:09 AM   #20
Alkhalil's Avatar
+. Ordered mine same day 5LHO posted it. Next day I got a confirmation that it shipped.
Old 07-31-2013, 08:58 AM   #21
Napoleon85's Avatar
FYI - Amazon has that Dorman gasket for $5
Amazon.com: Dorman HELP! 42098 Master Cylinder Gasket: Automotive
You can use any vacuum cap that fits and a zip tie on the intake tube. Should be able to piece it together for less than $12 if you want, but it's not an outrageous price.
Old 07-31-2013, 12:30 PM   #22
I got the required caps at the local parts store for FREE!!!
~2013 Mustang GT
Old 07-31-2013, 12:34 PM   #23
It's not me, it's you.
primer2tone's Avatar
Exactly!
Old 07-31-2013, 12:54 PM   #24
I appreciated the stealth bomber thinking that went into it, you get the noise you like but, the car isn't advertising itself to all and sundry. problem is, the sound just wasn't "right" because it was coming from ahead of the throttle plate so, it was kind of asynchronous slightly on timing and didn't sound like combustion aftereffects do.
Old 07-31-2013, 02:31 PM   #25
So if I'm reading thi correctly.... They should run a sound tube from the exhaust into the cabin!!
Not to be confused with running the EXHAUST into the cabin!!! Lol
But that would have made more sense (intake was probably easier and cheaper to do though)
~2013 Mustang GT
Old 07-31-2013, 02:58 PM   #26
Yeah, that's right. However, as you suggest, it's pretty hard to do that. BMW has a musical score it plays in its M5, which is just hilarious....
Old 07-31-2013, 04:51 PM   #27
I wonder if it'll sound better then the "Jingle bell exhaust"?
http://youtu.be/IIBoRXR95zE
Old 07-31-2013, 05:31 PM   #28
it's coming back:
The Whistles Go 'Wooooo!' - Bubb Rubb Makes His Internet Debut - WorldHistoryProject.org
Old 07-31-2013, 06:03 PM   #29
Nothing can beat this one!
Inner Tube Exhaust Preview - YouTube
Old 07-31-2013, 07:39 PM   #30
Car driver plays Jingle Bells with his exhaust.. Hilarious! - YouTube
I'm gonna do that!!
With a quad exhaust we could have a whole BAND of musical exhaust!!
~2013 Mustang GT
Old 07-31-2013, 08:39 PM   #31
Oh dear god. That is so gay.
Old 08-01-2013, 10:49 AM   #32
Here is what I did to mine. Put back the sound tube so not to lose it and just put the doorman gasket in the firewall.
Old 08-01-2013, 12:13 PM   #33
Not bloody likely, gay people have good taste and respect for their neighbours generally, at least in my experience.
Old 08-01-2013, 12:42 PM   #34
Mustang_96's Avatar
ID:	121585   Click image for larger version
Mustang_96 is offline   Reply With Quote
Old 08-01-2013, 01:48 PM   #35
tc x 4's Avatar
I'm glad I'm tone deaf, only thing I hear is my ABs.
07:31 AM
