cranking noise when turning left or right - Mustang Evolution
Old 07-28-2013, 06:44 PM   #1
Joey8's Avatar
So I just got Ford k springs koni str.t shocks and struts with gt500 mounts and a bmr panhard bar. When I'm notmoving and I turn the wheel left or right there is a cranking type noise that I can certainly hear. When I'm driving I can't tell if it's making the noise because of the exhaust. Also, when cleaning my tires I noticed some paint is coming off the rear shocks on both sides .is this normal or is something off?
2014 Sterling Gray GT (Ordered1/24) (Built2/25) (ETA3/12) (Picked Up 3/21)l 443.9/417.8 l
l l 6 Spd l Prem Pkg l Nav l TP l LthrRecaros l AmericanRacing 1 7/8 LTs l O/R H l JLT CF CAI lVMP Tuned l BorlaS Quads w/ResDel. l GT500Valance l KoniStr.T l K-Springs l GT500 Mounts l BMR UCA&LCA l BMR Relos l BMR Panhard l SpeedDawg Knob l 5.0 LloydsMats l Redline HoodStrts l Bobs CF Oil Sep. l 15% Tint l CDC Grille l StrtScn2 ChinSpoiler l GT/CS Fogs w/4500k l RTR DeckLid l CF Engine/CoilCoversl
Joey8 is offline   Reply With Quote
Old 07-28-2013, 07:32 PM   #2
Evil2014GT's Avatar
Go back and double check all your bolts. Especially the strut mount bolts and the sway bar end link bolts. Did you make sure to replace the bolts, or use locktite on them. As for the paint peeling off the shocks, i have about 6k miles on my str.t shocks, and when they are clean they still look brand new.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 07-28-2013, 07:38 PM   #3
Joey8's Avatar
I had them installed at a reliable mustang shop. When I go get my lcas and uca installed I'll have them check over everything. As for the rear shocks the orange paint is peeled off a bit right on the side facing out towards the tire...
Old 07-28-2013, 07:42 PM   #4
Evil2014GT's Avatar
I would have them double check for sure. Most people dont know the strut bolts are one time use only, according to ford, but most of us just reuse them and add locktite. As for the paint, again, i have no problems with mine, and its my daily driver. Maybe the chipped it when installing?
Old 07-28-2013, 07:45 PM   #5
Joey8's Avatar
That could be but it's in the same spot on both shocks in the rear. So I think they are rubbing when they compress against something but maybe it was when they were installed bc I don't see what they could be rubbing against when compressing . It doesn't bother me but imjust worried that something isn't right.
Old 07-28-2013, 07:56 PM   #6
Evil2014GT's Avatar
I seriously doubt the shock it rubbing on anything... Dont see what it could really be rubbing on.
Again, i would just have them double check all the bolts.
Old 07-29-2013, 12:22 PM   #7
ddinn25's Avatar
Your strut mounts are toast! Sounds like there is bearing damage or balls missing out of the mount. My stock mounts did this when I tried to re use them. When I took them out they crumbled to pieces
2013 5.0 m6 base 3.31's tint 20in Shelby razors 255/35/20 falken fk 452's koni srt.t's sr springs j&m phb gt500 mounts upr rear billet lower ca's upr brackets upr adjustable upper ca flowmaster at classics steeda cat deletes airaid cai premium st brace jlt catch can MGW shifter and blk ball. Currently bama tuned 400hp 383tq. Zex blackout kit w/msd digital window switch, fpss, zex bottle heater, bottle opener, blow down, and purge with a dyno tune coming soon..
ddinn25 is offline   Reply With Quote
Old 07-29-2013, 12:29 PM   #8
Evil2014GT's Avatar
Thats what i originally thought as well, but he said he put in new gt500 strut mounts with the struts. Hard to believe they failed so quickly, unless he got a bad part.
Old 07-29-2013, 12:29 PM   #9
Joey8's Avatar
I have the gt500 mounts...
Old 07-29-2013, 12:29 PM   #10
Evil2014GT's Avatar
Beat me to it haha
Old 07-29-2013, 12:39 PM   #11
Joey8's Avatar
I feel like if they failed it would be slot worse of a noise. I reallyhave to listen to it to hear the cranking/ticking noise.
Old 07-29-2013, 12:42 PM   #12
Evil2014GT's Avatar
I agree. Plus a failed strut mount will make more of a loud pop, then a faint tick
Old 07-29-2013, 01:22 PM   #13
tc x 4's Avatar
Sounds like a rear end problem to me.
Old 07-29-2013, 01:31 PM   #14
Joey8's Avatar
It sounds like it's coming fromthe front though . As I turn the wheelfaster sitting still the ticking cranking increases with however fast i turn the wheel.
Old 07-29-2013, 01:38 PM   #15
tc x 4's Avatar
I guess that eliminates the rear end then.lol
Old 07-29-2013, 01:44 PM   #16
Evil2014GT's Avatar
I know we have electronic power steering, and im not all too familiar with the way the system works, but maybe you could be having problems with that?
Old 07-29-2013, 01:48 PM   #17
Joey8's Avatar
I reallythink it may be the springs binding or something. When I cruise I don't hear it and would never no it's there unless I hear it. The steering feels the same as day 1 so it must be something with the springs or bolts .
Old 07-29-2013, 03:42 PM   #18
gtstyles2's Avatar
Do u hear it more when just starting a cold drive?? My stock mounts were reused and I hear noises at the beginning then they're faint and less noticable after driving it for a good while
Old 07-29-2013, 03:43 PM   #19
Joey8's Avatar
Hmm didn't even consider that. I'll see ofit gets better asthe car gets up to temp. I have the gt500 mounts not the stock mounts when I switched to the konis
Old 08-23-2013, 08:56 AM   #20
Joey8's Avatar
Update: when I took off the struttower bar to put on the new engine and coil covers I notice the cranking/ticking/binding noise was gone .when I put the strut tower bar back on it was back...
Old 08-23-2013, 11:56 AM   #21
The Blue Dragon
GrabberBlue5.0's Avatar
Well I just read the whole thread and I was gonna tell you about the front lower control arm tsb, they're known to do this a lot, but now that you talk about the STB I'm lost again.
As far as the paint, my shocks are bare in spots also, unfortunately when the shocks articulate the shock cover rubs the paint off those certain spots, it happens to many of us running STR.T shocks
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 08-23-2013, 12:19 PM   #22
Joey8's Avatar
Yeah its not a squeek/creak anything like that when going over bumps. its just the when turning the wheel left or right there is a consistent tick tick tick that gets faster or slower depending on the speed of the turn. This only happens when at idling or slowly moving into a driveway or such. When cruising at a normal speed I don't hear it when turning. Again, with the STB off i didn't notice it. How tight should the brace be bolted down?
Old 08-23-2013, 12:25 PM   #23
The Blue Dragon
Something crazy low I think 30 ft lbs or something, don't crank it down or you'll snap the strut mount studs
Old 08-23-2013, 12:29 PM   #24
Joey8's Avatar
Cool. It may be on there to tight causing some binding or something. Oh BTW im totally kicking myself for leaving the show right after the awards. I see the guys who stayed got to reap the benefits by getting featured in the AM video at the end. Very cool! Oh and the sound of your exhaust made me want LTs and an offroad mid pipe now. So that will be getting done within the month .. thanks dave... haha
Old 08-23-2013, 12:32 PM   #25
The Blue Dragon
No problem Joey, wish y'all could've come out to eat with us... But I booked it shortly after, I wasn't feeling so hot.
Thanks for the props too btw. If you want a good deal on headers let me know and I'll send you in the right direction
Old 08-23-2013, 12:34 PM   #26
Joey8's Avatar
Sounds good brother. Thanks
09:22 PM
