Pypes pype bomb axelback - Mustang Evolution
Old 07-30-2013, 08:03 AM   #1
Cwwiley's Avatar
I have 2013 GT with pypes pype bomb. The fittment is off on the passenger side. I have tried moving h pipe and it still shifts. Does anyone have any pics of what they did to fix it. Welded brackets or bending of brackets?
Cwwiley is offline   Reply With Quote
Old 07-30-2013, 08:11 AM   #2
I had to weld mine cause even thought the clamp was tight it still was loose on both sides.ill never buy pypes products again.with all the complaints Ive read about them i would've made a different decision.but there sound badass and before welding i positioned then to where they fit just center.
Torchred2010gt is offline   Reply With Quote
Old 07-30-2013, 10:46 AM   #3
Jaydog74's Avatar
Same here...had to weld mine in place...
Jaydog74 is offline   Reply With Quote
Old 07-30-2013, 01:55 PM   #4
MidnightBlueGT's Avatar
Borla, bassani, or slp is the way to go imo
Old 07-30-2013, 04:07 PM   #5
Wf2491's Avatar
Region: Arkansas
I had the same problem with my Pype Bombs. I loosened every clamp that I could find and then wrapped folded towels around the tips inside the cutouts to hold them in place without scratching the paint or the tips. I tightened all the clamps and had to tweak the hangers a little but eventually got a factory look to them. You are right! I will never buy Pypes again.
Wf2491 is offline   Reply With Quote
Old 07-30-2013, 04:12 PM   #6
Cwwiley's Avatar
Thanks for the responses. I ended up using a sleeve from an anchor bolt and put it on after the bracket and it holds no movement or vibrations.
Old 07-30-2013, 05:40 PM   #7
I mean of course mines a 10gt prem.the clamp was getting me mad so we just the hell with this I'm getting these welded.luckily was able to get it lined up.the left is in just a bit can't notice unless you really really look at it.just sucks that our 3v don't sound good with the stingers or the packs.my 2 favorite brands
12:43 PM
