Budgeting Suspension Build - Mustang Evolution
Old 08-03-2013, 11:38 PM   #1
dj_fiveoh's Avatar
I'm budgeting 2,000.00 to spend on suspension components for my five oh.
Any suggestions, guidance and/or knowledge would be awesome!
Sincerely,
The other dude with the mustang.
DJ
'12 Mustang GT(M6)
'99 Audi A4 Quattro(A5)
SOLD: '06 Pontiac GTO(M6)
"I cheated on GM with Ford... Don't tell Dodge!"
dj_fiveoh is offline   Reply With Quote
Old 08-03-2013, 11:55 PM   #2
The Ford Racing handling pack is hard to beat for the value. Some guys don't like the shocks, but I've got no complaints with my adjustables.
Grey 2011 GT Brembo, 3.73, ARH LT headers, catted x-pipe, Borla GT500 A/B, JLT cf CAI, MGW shifter, SCT, tuned, Boss oil cooler, Ford Racing springs & adj shocks, GT500 strut mounts, Steeda adj panhard/upper & lower arms. Roush 18x10" wheels with PS2 fronts, R888 305's rear. Eibach GT500 adj swaybars, Boss IM/Strut bar/steering wheel, Ford Racing 90mm TB, GT500 wing, BMR relo brackets, DSS aluminum driveshaft, Cervini Cobra R hood, 2014 GT500 headlight & rear end retrofit...
Matt K is offline   Reply With Quote
Old 08-04-2013, 12:09 AM   #3
dj_fiveoh's Avatar
With that 1 inch drop do you think i'd be able to fit 19x8.5 or 9 in front and 19x10 in the rear with 35 offset?
DJ
'12 Mustang GT(M6)
Old 08-04-2013, 12:19 AM   #4
dj_fiveoh's Avatar
So I think i'm going to start off with whiteline strut tower brace, sub frame connectors, steeda rear seat x-brace, panhard bar, and gt500 handling pack. that'll run me right around more or less 2500.00 I think.
DJ
'12 Mustang GT(M6)
Old 08-04-2013, 02:39 AM   #5
BlackBetty5.0's Avatar
For that price point you can do a full suspension job. shock/struts, springs, PHB, LCA, relos, UCA, mount, CC plates and whatever else. And still have money left over to go drinkn'.
BlackBetty5.0 is offline   Reply With Quote
Old 08-04-2013, 03:54 AM   #6
It's not me, it's you.
primer2tone's Avatar
BC Fully adjustable coilovers only cost $1000. If you wanna go that route. I did.
Old 08-04-2013, 03:59 AM   #7
dj_fiveoh's Avatar
I did some more research and I decided to go with eibach pro-plus kit, BMR low control arm relo brackets, BMR low CA's, BMR adj. PHB, Hotchkiss SFC's, Hotchkiss stabilizer plate, and whiteline strut tow brace. maybe some can bolts for future alignment issues.
DJ
'12 Mustang GT(M6)
Old 08-04-2013, 05:58 AM   #8
I'm not sure what whitelines stb looks like but I like a stb that bolts up to all 4 strut bolts on each side. It just seems more solid. I've got a Steeda stb and it only uses the 2 inner bolts on each side. (Kicks rocks)
Old 08-04-2013, 10:28 AM   #9
jayman33's Avatar
What are your plans with the car? Dont simply buy parts because you dont have them. WL STB is a sturdy piece however, can be a bit overkill and expensive. Figuring your plans and what you like would help me figure out a good suspension system recommendation. Stay away from FRPP and Eibach in regards to dampers, many who recommend them typically has experience with just these or just very limited experience. Ive ran many suspension components for street driven venicles, dragstrip or road course and have found koni and bilstein to be the best available for the cost and performance for the entry to intermediate level. I could recommend a kit that would satisfy your needs and leave you with about 500 dollars remaining.
A boss.....
jayman33 is offline   Reply With Quote
Old 08-04-2013, 11:34 AM   #10
ddinn25's Avatar
Don't use cam/cc BOLTS! There called crash bolts for a reason! With a good alignment -camber isn't an issue. I'm -1.9 deg and have NO tire ware issues.
2013 5.0 m6 base 3.31's tint 20in Shelby razors 255/35/20 falken fk 452's koni srt.t's sr springs j&m phb gt500 mounts upr rear billet lower ca's upr brackets upr adjustable upper ca flowmaster at classics steeda cat deletes airaid cai premium st brace jlt catch can MGW shifter and blk ball. Currently bama tuned 400hp 383tq. Zex blackout kit w/msd digital window switch, fpss, zex bottle heater, bottle opener, blow down, and purge with a dyno tune coming soon..
ddinn25 is offline   Reply With Quote
Old 08-04-2013, 12:08 PM   #11
dj_fiveoh's Avatar
What kit?
DJ
'12 Mustang GT(M6)
Old 08-04-2013, 12:32 PM   #12
dj_fiveoh's Avatar
...and isn't Bilstein and Eibach the same? Don't they integrate their parts?
DJ
'12 Mustang GT(M6)
Old 08-04-2013, 12:57 PM   #13
Tpost08's Avatar
I just got done doing eibach pro springs, koni shocks and struts, mm camber PLATES, and whiteline panhard bar. All that for right under 1100. All I need next is some Uca's and lca's. I'm not looking for a drift car. But a good looking street car that if I decide to do work, can kick some @$$ at a strip. Therefore. I don't need upgraded sway bars and stuff like that that'll really only benefit people that autoX.
Tpost08 is offline   Reply With Quote
Old 08-04-2013, 01:02 PM   #14
jayman33's Avatar
Not at all, I work closely with a few companies. There are many misconceptions on who works with who.
As far as a kit goes, it would be a kit with different brands that work well with one another.
Cc bolts are not ideal, any springs with a conservative drop (pro kit, hotchkis, etc) can be put into spec by any decent alignment shop.
Shoot me a pm.
A boss.....
Old 08-04-2013, 01:20 PM   #15
dj_fiveoh's Avatar
What are your trying to build your car to as far hp/tq rating?
DJ
'12 Mustang GT(M6)
Old 08-04-2013, 02:22 PM   #16
Tpost08's Avatar
It'll be a long build. Wife hates me spending money on it. Period. I get overtime money to put towards my car. I am currently switching axle backs from roush to gt500's. then going with an off road x and tune at the same time. I don't have numbers in mind but more of what will allow me to get the most out of my car without having to sell my body for extra cash I have started with suspension and will next go to power. Doubt I will ever go turbo or anything due to not really any tracks around me or being well enough afar in life to have the extra money. I'm 23 and freshly married with a new house note. I check cushions for spare change brother. Just a regular guy with a dream of a b.a. Car.
Old 08-04-2013, 02:45 PM   #17
alrefire's Avatar
You sound like me in 6 years :p
Old 08-04-2013, 02:45 PM   #18
dj_fiveoh's Avatar
I heard that! Nice stang BTW!
DJ
'12 Mustang GT(M6)
Old 08-04-2013, 03:00 PM   #19
Tpost08's Avatar
Thanks brother. Same to you. And I like the stripe. I just can't pull that trigger yet. I'm going for the all black theme for now.
Old 08-04-2013, 06:45 PM   #20
dj_fiveoh's Avatar
DJ
'12 Mustang GT(M6)
Old 08-05-2013, 07:23 AM   #21
BeachMonkey100's Avatar
I second that note! I have pictures to prove it lol
2006 Mustang GT Premium Satin Silver Metallic | 5 Speed Manual | Hurst Short Shifter | K&N CAI | JSR Strut Brace, FLCA Brace, Rear Shock Tower Brace | Flowmaster Axle Backs | Ford K Springs | JM Trackbar | 93 Bama Performance Tune
BeachMonkey100 is offline   Reply With Quote
10:41 PM
