Driveshaft clearence - Mustang Evolution
Old 08-08-2013, 10:59 AM   #1
Tapakegovagnaps's Avatar
I have a 4" Axle Exchange driveshaft and adjustable Eibach suspension. The driveshaft is contacting this plastic gas tank shield in the shaft tunnel. Has anyone had issues with this? What could fix the issue? Pinion angle or what? I had to raise the rear suspension to near stock height to prevent the shaft from rubbing when hitting everyday bumps in the road. I haven't tested it on big bumps on the highway yet, but I'm worried it may still hit.
Should've gone with a smaller DS! Thanks for any input you can provide...
ID:	122702   Click image for larger version
2013 GB GT MT- Track Pack, Recaros. Whipple 2.3, JLT CAI, VMP 3x Pass HE, 170 TSTAT, Flowmaster Outlaw/RTR AB, Magnaflow Tru X, SCT ITSX, Eibach Pro Street Coilovers, Axle Exchange Alum. D.S.,BMR Loop, SOS Dual W/ Aeroforce Duals, Boss Steering Wheel, Gt500 Shift Boot, Gt500 Spoiler, MMD Louvers and Hood Struts, Fays2, 3DCarbon Rear Diffuser, DBA Rotors, MGW Shifter, Forgestar CF5s
Tapakegovagnaps is offline   Reply With Quote
Old 08-08-2013, 11:06 AM   #2
Deerslayer's Avatar
Just installed a Dynotech Aluminum Driveshaft w/ Eibach lowering suspension already on the car. No clearance issues, but the Dynotech is a 3.5" driveshaft. Do you have an adjustable panhard bar?
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 08-08-2013, 01:10 PM   #3
Ah, yes I do, still haven't had it professionally aligned though as I continue to fiddle with the ride height...
I imagine that 1/2 smaller shaft doesn't have any issues, but I have never heard of this clearance issue with the 4". I've read a lot of people saying nothing but good things about the axle exchange shaft...maybe I'm the only lowered axle exchange user? Nahhhh....
Idk maybe if I lower it and set the Panhard bar perfect, the rear end can compress without contact, or I'll have to carve up the tank shield.
12:41 PM
