Diff cover - Mustang Evolution
Old 08-08-2013, 11:48 PM   #1
InfinibandGT's Avatar
Diff cover
This is probably a stupid question. I'm replacing my diff oil and putting a finned replacement cover on. Is there no gasket, just silicone?
I guess I could just see how the old one comes off...
Any help would be appreciated so I can avoid multiple trips to the parts store.
InfinibandGT is offline   Reply With Quote
Old 08-08-2013, 11:52 PM   #2
tc x 4's Avatar
Use both, gasket with a light coat of silicon to hold it in place.
Old 08-08-2013, 11:53 PM   #3
Doing LCAs, Royal Purple diff and trans oil. Thanks to the advice here.
Old 08-08-2013, 11:55 PM   #4
Ok, so this diff cover came with no gasket. It sounds like I need to get one. This is what I was wondering. Thanks.
Old 08-08-2013, 11:55 PM   #5
tc x 4's Avatar
That's a sharp cover, is it Ford racing?
Old 08-09-2013, 12:07 AM   #6
I bought this:
http://www.americanmuscle.com/steeda...iff-cover.html
There's no friking instructions. On the site, there are instructions for different diff covers.
There is this little plastic bag that says "vent plug for diff covers". I can't figure out where this goes. I've looked all over the cover. This little brass plug looks like its ready to be screwed in, somewhere, with teflon tape all over it.
Old 08-09-2013, 04:30 AM   #7
The Blue Dragon
GrabberBlue5.0's Avatar
You could just buy some of the silicone gasket maker and you'd be just fine. No need for a typical felt (or whatever they're made of) gasket
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 08-09-2013, 04:53 AM   #8
Ftodaro's Avatar
If there was no gasket then its a machined surface and no gasket is needed. You will need to use a sealant like Permatex, ultra gray, or black. You can buy at any auto parts store.
Frank
2014 GT, Track Package, Deep Impact Blue. Roush Axle back, MGW short shifter.
Ftodaro is offline   Reply With Quote
Old 08-09-2013, 04:58 AM   #9
Ubnbit's Avatar
Just another reason why I love this forum. Good help men.
Old 08-09-2013, 05:00 AM   #10
Originally Posted by InfinibandGT View Post
I bought this:
Steeda Finned Mustang Differential Cover - 8.8in (86-14 GT, Mach 1; 07-12 GT500; 93-98 Cobra; 11-14 V6) 555-8143
That plug is threaded on the axle. If you have had Ford do the TSB for axle oil vent then you will not need it. Look on top of the axle on the left side to see if you have a part that looks like a turkey baster. If not then the plug will thread in there.
sloppymax is offline   Reply With Quote
Old 08-09-2013, 06:03 AM   #11
Black on Boss's Avatar
"Engineered by Ford, improved by Steeda"
It's a Ford racing part that has been modified by Steeda
Old 08-09-2013, 10:35 AM   #12
Thanks for the responses. Much appreciated.
Old 08-09-2013, 02:49 PM   #13
As others said just get a RTV silicon and apply a light bead on the cover and around the bolt holes. Tighten it up and let it set for a few hours then add fluid.
Molonlabemike is offline   Reply With Quote
« Power | Mykey »
06:54 PM
