Problem with my Thermometer - Mustang Evolution
Old 08-23-2013, 01:15 PM   #1
MattmuchGT's Avatar
I'm having a problem with my thermometer, when i crank it up it stays to cold for about 5 minutes and then Barely heats up to normal, it usually takes about 20 minutes in park to heat up to normal. And I put my heat on and it blows warm just like it should. Does anyone know The solution?
MattmuchGT is offline   Reply With Quote
Old 08-23-2013, 02:01 PM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
Not sure what you mean, are you talking about your thermostat? Takes a while for the engine to heat up? If I drive mine easy it can take 3-5 mins before it reaches proper operating temp
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 08-23-2013, 02:16 PM   #3
bigmac3's Avatar
If you are talking about your thermostat like ^ said, it can take a few minutes to get warm. It is possible for your thermostat to stick open causing the warmup to take extra long. Finally it could just be your gauge or sending unit. Unplug your sending unit, located close to the thermostat housing and ground the wire with your key on, if the gauge is good, it will peg to hot.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
02:13 PM
