Cruise Control Doesn't Work - Mustang Evolution
Old 08-24-2013, 04:53 PM   #1
Tylerva5's Avatar
Hey everyone my name is Tyler I'm new to the forums and have run into my first problem with my 5.0. I recently installed the Boss Intake manifold and Custom tune onto my car. After installation I decided to go on a spirited drive and discovered my clutch pedal sticking down whenever I shifted above 7000rpm. So I did some research. (Apparently a common problem especially for you guys driving a BOSS) I came across the clutch pedal fix that involved removing the clutch assist spring and cruise control shutoff switch to stop the pedal from sticking down. I did this and it solved my sticking clutch pedal problem however I discovered my cruise control isn't working now. Have any of you guys had this problem after removing the clutch pedal spring. Any help is greatly appreciated.
2012 Mustang GT 5.0
Mods- Airaid CAI, Boss IM, BAMA Tuned, Flowmaster Hushpower Axle-Back, SR Performance Springs, 3.55 Gears, HID Fog lights, Hurst Short Throw Shifter, Barton 2 Post Bracket, Toyo Proxes 4 Plus tires on TSW Rockingham wheels 20x10 295/30/20 rear and 20x8 275/40/19 front.
Tylerva5 is offline   Reply With Quote
Old 08-24-2013, 05:31 PM   #2
Capt. Obvious over here suggests you look at the cruise shutoff switch you just monkeyed with. That's probably the issue. It kind of needs to work or the cruise will default to "off" for safety reasons.
Old 08-24-2013, 05:34 PM   #3
FortyBrandon's Avatar
Welcome I'm sure there is some more greetful advice coming your way
FortyBrandon is offline   Reply With Quote
Old 08-24-2013, 05:44 PM   #4
Tylerva5's Avatar
I was thinking that about the shutoff switch as well. And its looking like I can put it back the way it was and have cruise control and a sticking clutch pedal or leave it off and have a working clutch pedal and no cruise control. I guess my real question is to those of you that have done the clutch pedal fix and removed the assist spring and cruise control shutoff switch. Does your cruise control still work?
---------- Post added at 04:44 PM ---------- Previous post was at 04:42 PM ----------
Thanks hoping I can have the best of both worlds. Nothing more frustrating than having the extra ponies and not being able to use them.
2012 Mustang GT 5.0
Old 08-24-2013, 05:50 PM   #5
92mustang2.3's Avatar
You have to have that stitch hook up or you will get a service light but the assist spring will help from sticking to the floor at high rpms
---------- Post added at 06:50 PM ---------- Previous post was at 06:48 PM ----------
I've install the boss and replace the clutch line and put a barton two post bracket on and still can't shift pass 7200 rpm
92mustang2.3 is offline   Reply With Quote
Old 08-24-2013, 05:52 PM   #6
Tylerva5's Avatar
Did you do this to your mustang? If so can I just leave the Cruise control shutoff switch hooked up and in place? I didn't really understand why I needed to disconnect it in the first place. But did read somewhere that someone broke theirs by leaving it on and hooked up. Don't see how it could break though.
2012 Mustang GT 5.0
Old 08-24-2013, 05:55 PM   #7
Yes sir I did and just hook it back up you'll be fine
Old 08-24-2013, 05:57 PM   #8
Tylerva5's Avatar
I heard the stock pressure plate is garbage above 7000rpm. That's probably the issue. Sometimes it won't even let me into gear above 7200rpm. Doesn't grind just acts like it has something blocking it and wont go into gear until rpm's drop.
2012 Mustang GT 5.0
Old 08-24-2013, 06:03 PM   #9
Tylerva5's Avatar
Alright put the shutoff switch back into place and left the spring out. Thanks for the help
2012 Mustang GT 5.0
Old 08-25-2013, 08:28 AM   #10
That's a BINGO!
03:34 PM
