2014 GT Check Engine Light - Mustang Evolution
Old 08-25-2013, 09:58 AM   #1
I had a problem this morning when I left my house. When I hit the main highway outside of my neighborhood I accelerated and shifted from 1st to 2nd. There was a slight delay in acceleration when I shifted into second gear and then at 3500 RPMs the check engine light started flashing and the car had a serious reduction in power. I babied it to the next intersection and pulled over to turn it around. Once I got the car turned around the check engine light went out and the car seemed to be normal.
The only thing I have done to the car is Outlaw axle-back exhaust, put the JTL oil separator on the passenger side, and installed a drop in K&N air filter.
Anybody else ever experience this or know what could have caused it?
jlesp2013 is offline   Reply With Quote
Old 08-25-2013, 10:56 AM   #2
TaylorF25's Avatar
If you are still under warrantee ( in guessing you are) then I would have Ford take a look at it.
TaylorF25 is offline   Reply With Quote
Old 08-25-2013, 10:58 AM   #3
acornsmoke's Avatar
I just read about someone with the same problem , took it into the dealer and they just test drove it and it was fine. try disconnecting the battery? or bring it to the dealer you still have that beautiful warranty
acornsmoke is offline   Reply With Quote
Old 08-25-2013, 11:12 AM   #4
Thanks for the responses. I had planned on taking it back to the dealer. I was just curious if anyone else had this issue and what could cause it.
Old 08-25-2013, 11:27 AM   #5
There are a thousand things that could cause it so, your best move is take it in, unless you have a code reader at home.
This engine has a number of serious protection strategies built in to the programming so, you likely triggered one of those.
Old 08-25-2013, 11:58 AM   #6
TooSlow4U's Avatar
When you have a problem with your car and its still under warranty,...take it to the dealer. Everyday there's a thread like this and every response is the same "take it in."
TooSlow4U is offline   Reply With Quote
Old 08-25-2013, 12:52 PM   #7
LovinmyGT's Avatar
This has happened to me bout 10 times or so took it to the dealership it was my cylinders misfiring.. and they have no clue what to do, so they will prob reflash your pcm and tell ya its good..
LovinmyGT is offline   Reply With Quote
Old 08-25-2013, 01:18 PM   #8
Thanks. I've been reading up on this a little bit and have to say I'm a little discouraged by what I've been reading. It sounds like there is a problem but Ford doesn't know what to do. At any rate, I will make an appointment and take it in and see what happens. Again thanks for the reply.
Old 08-25-2013, 02:21 PM   #9
Grabber Blue5.0's Avatar
Sounds like it went into limp mode.
Old 08-25-2013, 03:07 PM   #10
LovinmyGT's Avatar
Yea they keep givin me the run-around last time I took it in I brought it to AutoZone a couple days earlier and they said cylinder 1 and 4 misfired and cylinder 1 was a permanent misfire, took it to the dealership and they said sorry there's no codes so we can't work on it.. either AutoZone cleared the codes or they don't want to work on it, but I'm tired of dealing with this problem, especially reading how everyone else tunes there stangs and mods the hell outta them with no problems.
Old 08-25-2013, 07:54 PM   #11
A lot of people have similar stories. Seems if you get the light you need to take it right to the dealer and get it checked, otherwise when you turn the car off it will clear the code unless it happens more than once in the same cycle. I don't really know but I am going to the dealership tomorrow. Hopefully they can figure something out. Good luck to you, hopefully they figure something out for you soon.
---------- Post added at 09:54 PM ---------- Previous post was at 09:53 PM ----------
Yeah I'm pretty sure it did. But the funny thing was as soon as I pulled in a side street and turned around the light went out and it went right back to normal operation. Seems kind of crazy to me.
Old 08-25-2013, 08:50 PM   #12
the END's Avatar
I know we aren't quite the same but my '10 GT did this. Only difference was it didn't recover. Just lost a ton of power. It was a sensor. Can't recall which one as it happened at 500 miles or so. Really early. Throttle body I want to say.
---------- Post added at 08:50 PM ---------- Previous post was at 08:46 PM ----------
I should clarify as that isn't a common term. Throttle position sensor. But like I said it was really long ago. And different engines.
the END is offline   Reply With Quote
Old 08-25-2013, 09:01 PM   #13
You don't lose any codes if you turn the car off. They have to be selectively deleted by Ford IDS or any other tuner or diagnostic black box.
An interesting insight: If you have tech pack, you can check your own codes without anything. Just press 3 and 6 simultaneously on the radio and you can enter bezel diagnostics, which will allow you to view DTCs and clear them.
Old 08-25-2013, 09:48 PM   #14
LovinmyGT's Avatar
Thanks bleep2013 hopefully yours gets sorted too good luck
Old 08-25-2013, 09:56 PM   #15
LovinmyGT's Avatar
I'm gonna try this soon as I get off work lol thanks
Old 08-26-2013, 04:28 PM   #16
UPDATE: Took it to the dealer today. They couldn't read any codes (apparently none registered). Said it could have been a misfire and if it was it has to happen several times in a row on the same cylinder before it will register a code. Said it also could have been the K & N air filter. Apparently it can cause a slight oil mist to hit the Mass Air sensor and cause a check engine light and put the car in limp mode. I'm a little skeptical of this scenario but I suppose it is possible. The service adviser was really cool so I don't think he was trying to jerk me around or anything. I'll just keep an eye on it and see what happens.
---------- Post added at 06:28 PM ---------- Previous post was at 06:27 PM ----------
Thanks for the tip! I'm going to try this out tonight and next time I will know.
Old 08-26-2013, 08:51 PM   #17
You should have your dealer performance this TSB, on an other forum many user have resolve this issue with this TSB.
http://www.fordservicecontent.com/pu...sb13-06-15.pdf
Dineau is offline   Reply With Quote
Old 08-26-2013, 09:03 PM   #18
Thanks! If I have this issue again I will be sure to bring this up.
Old 08-27-2013, 08:01 AM   #19
normally you can replicate the issue easily...
With cold engine, drive wile mainting RPM around 4k RPM or accelerate hard while the engine is cold and the CEL should flash.
check engine
09:51 PM
