Airbag resistor kit! - Mustang Evolution
Old 08-25-2013, 06:08 PM   #1
McQueen's Avatar
So with the new racing seats my airbag light will come on and the only kit that I can find to delete the light is the recaro kit and it is 75$.
Is there a cheaper kit or can I make one myself? I have seen some people make their own online but don't know which would actually work and work best. HELP!!!!
McQueen is offline   Reply With Quote
Old 08-26-2013, 04:07 PM   #2
Mr. Anderson's Avatar
yup,
bought the 05-10 simulators from ford (for those cars that didn't have that option, and soldered in resistors from radio shack
here, read post 54, I gave devildog the instructions on how to do it, dno't forget you need to swap the passenger side bladder out: he just did a small how to:
http://www.s197forum.com/forum/showt...air+bag&page=3
Mr. Anderson is offline   Reply With Quote
Old 08-27-2013, 10:56 AM   #3
McQueen's Avatar
Thanks, I can't see the website for some reason. How many ohms is the resistor needed ??
Old 08-27-2013, 06:43 PM   #4
2 ohms, I just bought a 5 pack of 10 ohm resistors at radio shack and put them in parallel and soldered them in.
Old 08-27-2013, 08:38 PM   #5
McQueen's Avatar
You soldered all 5?
Old 08-28-2013, 07:03 AM   #6
Yes, five 10 ohm resistors in a parallel circuit equal 2 ohms. I did this because the 1/4 watt resistors pack was like 2 dollars at radio shack. I'm sure you can find a 2 ohm resistor online but after shipping and waiting for it it'll be more than 2 dollars.
Old 08-28-2013, 10:33 AM   #7
McQueen's Avatar
I got these, are they right???
Old 08-28-2013, 10:44 AM   #8
McQueen's Avatar
Old 08-28-2013, 10:54 AM   #9
McQueen's Avatar
Can I attach them to them self or do I need a wire to connect each.
Sorry for my ignorance on the subject, lol
Thanks for the help!!!
ID:	126269   Click image for larger version
Old 08-28-2013, 12:01 PM   #10
yes those resistors are the correct ones
love the artwork! yes, your picture is what they should look like. I just twisted/spiraled all the leads on mine and then soldered them together. I am assuming you did not get the 05-10 dummy load ford sells? if so not a big deal you should be able to just connect the leads to the airbag plug. I forget if that connector has male or female leads. whichever it is you could just get the opposite leads and crimp or solder the two ends to them and then attach them to the connector.
I would also recommend getting a large diameter piece of heat shrink to cover connector. not a high voltage circuit, but you don't want that grounding out on anything!
*edit- almost forgot, if your gonna go that route make sure you put some heat shrink over each side of the leads, so they don't touch each other, that will also short out the circuit.
Old 09-02-2013, 07:52 AM   #11
McQueen's Avatar
So I got all five in parallel and did a test run by just attaching the wires to the plug and it didn't work, the air bag light was still on. Should I use a bigger resistor or what could I have done wrong? Help!
Old 09-02-2013, 09:36 AM   #12
tc x 4's Avatar
Five 10 ohm resistors in parallel, is still 10 ohms.
Old 09-02-2013, 10:25 AM   #13
did you put both the drivers and passengers rail sensors back in also?
did you do a resistor pack for the passengers side?
tc x 4, you're incorrect. it's 2 ohms.
lemme break it down for ya, here is one of the ways to solve for Rt ( total resistance) in a parallel circuit:
the equation for resistance in a parallel circuit:
(R= resistance)
Rtotal = 1 / 1/R1 + 1/R2 + 1/ R3 + 1/R4 + 1/R5
substitute:
Rt = 1 / 1/10ohms + 1/10ohms + 1/10 ohms + 1/10ohms + 1/10ohms
do the math:
Rt = 1 / .1 + .1 + .1 + .1 + .1
continue work:
Rt = 1 / .5
vee-oh-lah!
Rt = 2 ohms
Old 09-02-2013, 10:43 AM   #14
Deerslayer's Avatar
no, it would be 2 ohms. A fifth of the current (five resistors) will experience 10 ohms of resistance so the equivalent resistance would be 2 ohms.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 09-02-2013, 11:00 AM   #15
tc x 4's Avatar
You guys are correct, I'd just woke up. Parallel is 2ohms, series is 50.
Old 09-02-2013, 03:33 PM   #16
McQueen's Avatar
(R= resistance)
substitute:
do the math:
continue work:
Rt = 1 / .5
vee-oh-lah!
Rt = 2 ohms
All I did was put the 5 resonators in the passenger side with the stock seat in the driver side.
Do I need to pass something from the older seats? Is there a way to not need anything from the other seats and make the airbag work all the time without the weight sensor?
Old 09-02-2013, 04:21 PM   #17
okay, there are three things on the passenger side that need to hooked up. 1. the air bladder, care must be taken when removing it from the stock seat, it's in the lower section and it senses the weight of the passenger in the seat. and it needs to reinstalled in the new seat. 2. the seat track sensor, this is in the stock seat track and is a magnetic type sensor, look at the stock seat and find the sensor. remove it and install it on the aftermarket seat rail.( I had to rig mine up to work with the corbeaus. 3. and the resistor pack that you added. all these need to be in working order or you'll get a error.
Old 09-02-2013, 04:32 PM   #18
McQueen's Avatar
Ok perfect the only thing is that I don't have a rail since mine are fix seats.
Old 09-02-2013, 04:32 PM   #19
McQueen's Avatar
And for the driver what do I need?
Old 09-02-2013, 05:05 PM   #20
Black on Boss's Avatar
This looks like it's getting way to complicated for me lol
Old 09-02-2013, 05:28 PM   #21
just the resistor pack and the seat position sensor for the drivers side. no need for an seat weight sensor as if your driving then it's a given there is someone in the seat, and it's not a infant or child.
Old 09-02-2013, 05:33 PM   #22
McQueen's Avatar
Man thank you a million, I couldn't have done this without you. I have everything 100% clear now, I thing lol
Old 09-02-2013, 05:41 PM   #23
no problem, lemme know if ya got any other questions.
Old 09-02-2013, 08:43 PM   #24
McQueen's Avatar
One last question!
I don't have sliders BC my seats are fix, what do I do with the slider sensor them?
Old 09-03-2013, 10:04 AM   #25
hmmm. that one may provide interesting. the sensor seems to be of a magnetic type. might be able to get the actual sensor within close proximity of base of a ferrite material (1/8"- 1/4") somewhere, heck anywhere since the seats are stationary.
Old 02-06-2016, 06:38 PM   #26
Mr. Anderson,
Thank you for the answers to the airbag question.
My challenge goes a bit deeper. I am using the complete harness and computer from a wrecked 2014 Mustang GT in a 1967 TVR. In essence, complete shift to a vehicle that has no safety standards, nor requirements. I have no airbags, nor sensors for accidents, and only wish to use the engine management, transmission management (6-sp. automatic), drive by wire, as well as all driveline and braking (ABS and Hub Sensors) electronics, none of the seat nor airbag systems as there is nothing there. Any way to just eliminate these systems, or will I need resistors at each one of the connections?
TVRV8 is offline   Reply With Quote
Old 10-12-2016, 11:34 AM   #27
I first tried the airbag delete plug from Ford, it did not work, so I have my airbag light on now.
I replaced the original resistor (~7 ohms) and with a 2 ohms one. Unfortunately, the airbag is still on now. How do I turn off the airbag light? Should I depower and repower the airbag system?
Thanks.
2014 Mustang 3.7L cyclone engine with 6 spd transmission. Mods: 93 MPT Race Tune, 3.31 Gears, Airaid CAI, BBK Shorty Ceramic Headers, Corsa Sport axle backs, Strut Tower Brace, Steeda rear seat X-brace, BMR Rear LCAs, GT wheels, MGW race spec shifter, Passenger seat delete, spare tire delete, Moroso battery relocation to the trunk.
liv4spd is offline   Reply With Quote
04:00 PM
