koni squeaking - Mustang Evolution
Old 08-25-2013, 08:56 PM   #1
koni squeaking
Ok heres the deal. Ive been chasing a squeak for weeks and ive pinpointed it. I sprayed my koni struts with silicone lubricant, the actual strut rod, and my squeak vanished for 2 days. Its back today, although not as loud as before. So what could be causing this? And is there a better fix than silicone spray? Would lithium grease be more permanent? I wonder if my shocks are bad. Any advice would be great.
Mikeyt03 is offline   Reply With Quote
Old 08-25-2013, 10:41 PM   #2
blackbeast12's Avatar
Region: Delaware
Is it both struts or just 1, they will replace it just call them!
2016 Gt/Cs autowith 3:55', mbrp cat back and a n/a build on the way!...
blackbeast12 is offline   Reply With Quote
Old 08-26-2013, 04:29 AM   #3
Well. The problem is, I cant send them back unless I have the replacements first. I think its both, but im not sure.
Old 08-26-2013, 05:32 AM   #4
OzzyLiriano's Avatar
Mike i did my install and had no problems, have you considered removing the strut engine mount?
OzzyLiriano is offline   Reply With Quote
Old 08-26-2013, 08:06 AM   #5
Region: Delaware
Most companies understand that you cant take them off until you have replacements and will send the new ones 1st with a return fedx lable for you to send the old ones back! Call them koni is a good company!
06:09 AM
