Bogging at 3K RPM - Mustang Evolution
Old 08-29-2013, 08:20 PM   #1
Bogging at 3K RPM
So I had the procal installed on my 2012 gt about 2 months ago. Love it. However, it's been recently bogging right around 3K. WOT and from 3000 to 3400ish it's like it just loses 50% power. Then it comes back on. Mostly in 3rd and 4th gear.
Any thoughts? Noticed it once before the procal but seems like it's not going away now. Also, oil life meter dropped from 100% to 0% in about 4 weeks. Noticed more black dirt on decklid and bumper-from exhaust?
ericd306 is offline   Reply With Quote
Old 08-30-2013, 04:04 PM   #2
And to make matters worse - was 5 quarts low on oil this morning. What the hell.
Old 08-30-2013, 04:27 PM   #3
mustangchassy's Avatar
Wow holy hell. Do u still have a warranty?!
2013 GT Premium: 15% Tint/Roush Axleback/Gloss Black 5.0 Badges/2007 GT Premium (SOLD)
mustangchassy is offline   Reply With Quote
Old 08-30-2013, 04:57 PM   #4
tc x 4's Avatar
Try checking you oil like your supposed too, you won't have that problem. There's no way you lost that much on a tank of fuel, unless your filter is not tight.
Old 08-30-2013, 05:23 PM   #5
Grabber Blue5.0's Avatar
Checking ones oil is a lost art...........................
Old 08-30-2013, 06:07 PM   #6
TooSlow4U's Avatar
I hear that!
TooSlow4U is offline   Reply With Quote
Old 08-30-2013, 10:08 PM   #7
Dealer changed the oil 6 weeks ago. Not like 6 months has gone by here. And regardless, there's clearly a problem.
Old 08-30-2013, 10:22 PM   #8
Black on Boss's Avatar
Sucks BC you are tuned so they are going to deny any warranty work regardless
Old 08-30-2013, 10:31 PM   #9
Yep only at 20K miles. Procal was installed by dealer. Service manager cleared the installation. Plus, Ford Racing has 36K warranty.
---------- Post added at 11:31 PM ---------- Previous post was at 11:29 PM ----------
Nope was installed by dealer and precleared in writing. This is why I chose the procal over better tunes.
Old 08-30-2013, 10:39 PM   #10
I would be shocked if they had to replace an engine for you and actually replace it under warranty. Just BC the installer said ford will cover it don't mean they actually will. Just my .02
Old 08-30-2013, 11:26 PM   #11
acornsmoke's Avatar
if it's in writing its in writing
acornsmoke is offline   Reply With Quote
Old 08-30-2013, 11:36 PM   #12
tc x 4's Avatar
There's definitely a problem, regardless your oil needs to be checked every fill up. That's how you detect something minor that becomes expensive quick. Doing the math on gas mileage is also a good way, when it starts to vary, somethings up.
Old 08-31-2013, 05:46 AM   #13
Is it possible it was incorrectly filled?
Regardless that's why I do all my own work, period. I trust my ability over any Ford dealer.
Old 08-31-2013, 07:30 AM   #14
You keep thinking that
Old 08-31-2013, 12:55 PM   #15
Evil2014GT's Avatar
His warranty is no longer with Ford, so your right, they won't pay for it. However he does now have the same 36k mile powertrain warranty through Ford Racing. As long as the Procal tune was installed by a Ford technician, he will be covered. As the OP stated, that is a huge reason people go for the procal tune, as Ford Racing offers the warranty with it.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 09-04-2013, 08:10 PM   #16
New short block is on the way from ford...
Old 09-05-2013, 04:52 AM   #17
Is there more to the story?
Old 09-05-2013, 11:52 AM   #18
Wait, so modifying a car wipes the warranty right off the slate? Since when did that happen? Are you saying anything drivetrain related is no longer with Ford, but with Ford Racing now?
I've read that when you modify the car, and by chance something on the car goes wrong, Ford has to prove that the modification(s) you installed are the cause of the fault (e.g. suspension fault, check engine, etc.).
For example; If you install a supercharger on Day 1, you drive for 10 days, suddenly your rear axle starts chattering/clicking. So you take the car to Ford, tell them the problem, they re-create the scenario and find the rear end to be faulty.
NOW, from my understanding, you aren't required to tell them about any modifications, so pretty much you pull the car in, tell them the problem, and sit down and wait. I read where someone had a major engine mod, and they replaced the transmission and the Ford Tech's didn't ask/see the modification and they replace the transmission, no charge, out the door. On the other hand, if they DO see/find the modification you've done, they have to prove the modification is what caused the, in the previous example, rear end to be at fault...
This is just my understanding and in no way how it will be at every Ford Dealership
cstone94 is offline   Reply With Quote
Old 09-05-2013, 12:00 PM   #19
You are almost right lol. If Ford says your mods caused failure, YOU have to prove that they didn't.
Old 09-05-2013, 12:08 PM   #20
I thought I was. I know for sure that modifying your car doesn't literally just throw your warranty away. An explanation of the warranty situation should be a sticky for everyone to reference to and clear up confusion.
Old 09-05-2013, 12:55 PM   #21
Missouri Hoss's Avatar
Actually, the standard Ford powertrain warranty is 5yr/60,000.
Missouri Hoss is offline   Reply With Quote
Old 09-06-2013, 10:24 AM   #22
Evil2014GT's Avatar
Yes, the standard powertrain warranty from Ford is. But the bumper to bumper warranty is only 3/36k. Im not positive, as i dont have one, but i believe ford racing only covers your powertrain for 3/36k with the procal tune. Someone correct me if I'm wrong. And then obviously with any tune, your factory powertrain warranty will be voided (if the dealer can prove the tune caused the failure).
Old 09-18-2013, 12:35 AM   #23
DallasStang77's Avatar
I cannot CANNOT imagine driving my 13 GT bone stock for 5/60k...
Dropped the car at 1000miles. CAI and tuned it at 2K. Have I already said that I love my car?
Need a name for her now as much as I baby her... Ummmm it.
04:32 AM
