HI/LOW are reversed HID bi-xenon kit - Mustang Evolution
Old 08-30-2013, 03:13 PM   #1
dj_fiveoh's Avatar
I've done a little research and I know I'll have to probably do some re-wiring on these.
Should I re-wire off the HID bulb connector or the main lighting harness connector?
Which wires would I be re-wiring? I unfortunately don't have access to a volt meter/test light at all. I'm sure I could borrow one from Auto Zone or something but I just wanted to check on here first.
DJ
'12 Mustang GT(M6)
'99 Audi A4 Quattro(A5)
SOLD: '06 Pontiac GTO(M6)
"I cheated on GM with Ford... Don't tell Dodge!"
dj_fiveoh is offline   Reply With Quote
Old 08-30-2013, 03:37 PM   #2
1slosix's Avatar
if the polarities are reversed just swap the hi and low wire on the harness side...at least that's what i did on my last mustang that had that issue.
carving corners like a boss
Old 08-30-2013, 03:50 PM   #3
tc x 4's Avatar
You can buy a cheap multi meter for less than $10.
Old 08-30-2013, 06:35 PM   #4
dj_fiveoh's Avatar
Thanks
DJ
'12 Mustang GT(M6)
Old 08-30-2013, 07:11 PM   #5
Doe_Rae_mi's Avatar
I have these and u will need to reverse the wires like said above
Old 08-30-2013, 07:40 PM   #6
Most HID kits today have polarity protection in the ballasts anyway so, you aren't risking an expensive fire any more.
Old 08-31-2013, 02:12 PM   #7
dj_fiveoh's Avatar
Thanks everyone I fixed it however there were no tabs to lock the wires in place. I think I'll need to replace the spades one of these days. Temporary fix.
DJ
'12 Mustang GT(M6)
02:50 AM
