High Flow Fuel Rails - Mustang Evolution
Old 08-31-2013, 10:47 AM   #1
SELENE's Avatar
Region: Oregon
Has anyone purchased and installed the Metco Motorsports High Flow Fuel Rail Kit (available at AM and JLT)? I am going to install the Boss 302 intake manifold and JLT carbon CAI soon and thought the better fuel rails might compliment the installation. Thoughts?
Honestly, I'm a noob when it comes to engine upgrades. Please go easy on me...
2013 Sterling Gray Shelby GT500
SELENE is offline   Reply With Quote
Old 08-31-2013, 12:05 PM   #2
Grabber Blue5.0's Avatar
Save your money. You don't need them.
Old 08-31-2013, 12:09 PM   #3
Fader's Avatar
Region: Idaho
My understanding is that, unless you are going to use higher-flow injectors, hi-flow fuel rails are a waste of money. I don't think they'll do a thing for your motor without new injectors. Picture using a fire-hose with a garden-hose sized sprayer. No point in it.
Also, I've heard that there are no better injectors than the standard, OEM injectors. Aftermarket seems to cause a lot of issues for folks.
A new intake manifold probably won't do much for you either, if you aren't putting a new Throttle Body between the CAI and intake. Same concept I used earlier with the fire-hose with garden-hose sprayer.
Remember, a CAI and manifold will likely need a tune for your motor, either way. When you change the air/fuel stuff, the computer can only do so much to compensate and adjust.
Just my opinion, but I'm not sure the stuff you want will be effective without other purchases.
Fader is offline   Reply With Quote
Old 08-31-2013, 12:17 PM   #4
1lowGT's Avatar
Yeah spend money elsewhere.
Old 08-31-2013, 12:19 PM   #5
SELENE's Avatar
Region: Oregon
Thank you - I appreciate your reply. I do have an 85mm TB and a tuner already. I'll pass on the fuel rails, as I do not plan to ever upgrade the injectors.
Old 08-31-2013, 12:20 PM   #6
1lowGT's Avatar
Don't plan to never do it but you don't need them with the upgrades you got now. Future mods might require them.
Old 08-31-2013, 12:24 PM   #7
SELENE's Avatar
Region: Oregon
Fair enough - Point taken.
Old 08-31-2013, 12:28 PM   #8
Fader's Avatar
Region: Idaho
OK. Since you have the bigger TB and tuner, the CAI will be fine. Still not sure the intake manifold is necessary. I'd invest in a better exhaust system, instead. Then tune appropriately.
An intake manifold, and the hi-flow injectors could be necessary if you do some work inside the engine, but plan carefully so as to maximize the gains vs. expense.
Good luck! I'm no mechanic either, but am learning from the folks around here. Keep asking questions!
Old 08-31-2013, 01:11 PM   #9
SELENE's Avatar
Region: Oregon
Again, thank you for your input! I appreciate it!
Old 09-01-2013, 12:19 AM   #10
MaggioM's Avatar
NO NEED , enjoy your stock rails
MaggioM is offline   Reply With Quote
01:03 PM
