Limited Slip Dif? - Mustang Evolution
Old 09-05-2013, 08:56 AM   #1
BIGHOSS5.0's Avatar
Limited Slip Dif?
I am thinking about upgrading my 12 GT gears to 3.73..Do you think it is worth it to add either the Eaton 8.8in 31 Spline Mustang Limited Slip Differential 19588-1 or the Ford Racing 8.8 in 31 Spline Traction - LOK Mustang Limited Slip Differential w/ Carbon Discs M-4204-F318C
Mostly daily driver, some weekend hole shots and your occasional track day (Road Course)
I read some of the other threads on Limited Slip Dif's but none of them answer my question...They were mostly trolls who didn't no anything
BIGHOSS5.0 is offline   Reply With Quote
Old 09-05-2013, 09:18 AM   #2
You already have an Trak Lok LSD so, all you'd need are the carbon clutches and a shim kit for that upgrade. Eaton's good all round, no question. The factory T-lok, set up really tight, will surprise you. It works well and is almost eternally rebuildable.
Old 09-05-2013, 09:21 AM   #3
BIGHOSS5.0's Avatar
I did not get the track pack option on my mustang, dose it still have the trak lok? I knew I was going to build it the way I want it anyway, so I did not waste my money on any of the fancy options..
Old 09-05-2013, 10:42 AM   #4
All 5.0's have Limited Slip. I think the Track Pack is the only one with the Eaton, but I could be wrong!
cstone94 is offline   Reply With Quote
Old 09-05-2013, 11:13 AM   #5
Track Pack has the torsen style rear diff instead of the clutch type.
SpaceFish is offline   Reply With Quote
Old 09-05-2013, 11:21 AM   #6
Oh okay! I just looked up what all the track pack includes, and it said it has the same rear axle assembly as the Boss 302. So I guess to answer the OP's question, he does have Trak Lock.
Old 09-05-2013, 11:24 AM   #7
Yes - all of the current Mustang V-8s have some form of limited slip differential - it's either clutch or helical style depending upon which one.
Here's a handy read about how the torsen style is different.
http://www.torsen.com/files/Ford%20M...2%20Torsen.pdf
HTH
Old 09-05-2013, 11:43 AM   #8
BIGHOSS5.0's Avatar
So basically, I will be fine running stock...???
Old 09-05-2013, 11:45 AM   #9
You should be fine just changing out the gears many others on the site have done the same.
Mine came with 3.73s and I love them (except when I'm stuck driving around town and have to fill the tank up more frequently, but it's worth it to me).
Old 09-05-2013, 07:13 PM   #10
Yes, you'll be fine running stock. I have numerous times in the past played with shim and restacked the plates in T-loks and had them work as good or better than aftermarket setups.
The factory 3.73 cars got the carbon clutches from the factory on these cars, a little easter egg I found and proved when I opened my own to change the fluid out.
Old 09-05-2013, 07:22 PM   #11
BIGHOSS5.0's Avatar
Thanks everyone...Very helpful
Old 09-05-2013, 07:56 PM   #12
Black on Boss's Avatar
HTH
Good read. To bad they can't spell Leguna Seca lol
06:26 PM
