Adjustable control arms or Regular - Mustang Evolution
Old 09-06-2013, 06:13 AM   #1
1st stang's Avatar
Should I get adjustable control arms or can I just go with steeda's Stop-The-Hop-Pak?
1st stang is offline   Reply With Quote
Old 09-06-2013, 06:20 AM   #2
Deerslayer's Avatar
If you are lowering, I would go with the adjustable, if not, the STHP will be sufficient.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 09-06-2013, 06:23 AM   #3
Jayday20's Avatar
Not to hijack the thread but if you are lowered an inch on p springs would adjustable still be the way to go or would non adjustable be sufficient. Thanks
Jayday20 is offline   Reply With Quote
Old 09-06-2013, 06:35 AM   #4
1st stang's Avatar
I have steeda springs that lowered it 1" front and 1.25 in the rear
Old 09-06-2013, 06:37 AM   #5
Deerslayer's Avatar
-1" lowering, you should be fine with the non-adjustable.
(We are -1.5 and our pinion angle needs to be adjusted slightly. The adjustable upper will get the angle back to spec.)
06:33 AM
