$10k for upgrades need advice - Mustang Evolution
Old 09-08-2013, 09:48 PM   #1
Black on Boss's Avatar
Let's say I have $10k just laying around to mod the boss with. What mods should I buy and why? Let me start by saying I am not looking to do any type of forced induction. I will be tracking the car on a road course. Looking mainly for suspension, bolt on upgrades, cooling, breaking etc
Old 09-08-2013, 09:59 PM   #2
McQueen's Avatar
With 10k u would have a lot of things done!!!!!!
For the track my #1 advice is upgrading the brakes. For the first few times the last thing u will want is more power lol. Specially with a boss
McQueen is offline   Reply With Quote
Old 09-08-2013, 10:01 PM   #3
Bolt on rear end brace on AM. Only requires two holes drilled in the pumpkin. Wilwoods for brakes.. That's my brand of choice and dot 3-4 fluid. Lower it, cage it, take weight off, and use water wetter!
Old 09-08-2013, 10:13 PM   #4
You pretty much nailed what's in my mind. I'm thinking just like McQueen also Im about to order some HPS brakes BC it is my dd as well. Then I'm thinking maybe the rear brake upgrade, lowering it, maybe even coil overs, maybe that rear end brace, rear seat delete or full on roll cage like McQueen lol racing harness, by that time I will probably break down and finally have it tuned
Old 09-08-2013, 10:19 PM   #5
Oh I forgot the most important thing new rims and sticky tires. I'm most likely going 18x9.5or10 all around. Maybe gold or black Forgestar's 18x10 all around with some sticky ickys on there
Old 09-08-2013, 10:20 PM   #6
McQueen's Avatar
WHATT??? U still not tuned?? Shame on uuuuuuuu lol jk
I have the HPS for dd and if u want for track days get the hp plus, just take it easy on the first lap because they need to be HOT to work correctly and on the streets they sound like a train stopping lol it is so embarrassing everyone looks at u like ur brakes are F up lol
They have a big *** sign in the back saying "not for drag racing" lol
Old 09-08-2013, 10:21 PM   #7
MidnightBlueGT's Avatar
Turbooooooo
Old 09-08-2013, 10:23 PM   #8
McQueen's Avatar
Sve or AM are a much better choice price wise for track rims also lightweight. If they F Up it wouldn't hurt as much but if u have the $$$$ then get the forgestar. Hoosier R6 295 30 18 on a 18x10 is a good set up.
Old 09-08-2013, 10:24 PM   #9
You know I said I was going to stay stock for ever lmao. That's why I sold every mod I had except this
I knew the itch would come sooner or later. I'm thinking VMP for my tunes. What do you suggest other than a dyno tune?
Old 09-08-2013, 10:25 PM   #10
McQueen's Avatar
Originally Posted by MidnightBlueGT View Post
Turbooooooo
U crazyyyy!!!!! Not for the road course lol
---------- Post added at 10:25 PM ---------- Previous post was at 10:24 PM ----------
I am happy with the BAMA, I done data logging and they really got my tune 100% right.
Old 09-08-2013, 10:26 PM   #11
I've heard the ams are heavy and the quality sucks. The enkie and Forgestar's are right at 20lbs a piece. I need to get a one piece shaft as well.
Old 09-08-2013, 10:27 PM   #12
Lol my car isn't tuned an doesn't have brembos! I have fluid swap, and hawk pads. I don't road course either. Just drive fast sometimes and try to "look cool" at car show
Old 09-08-2013, 10:29 PM   #13
So I'm gonna ask this. Do you know anyone running meth on the track NA? Over the last couple hours I have read some good stuff about it. Any thing I need to do to use it? It basically turns your gas into race fuel and helps cool everything down.
Old 09-08-2013, 10:29 PM   #14
1slosix's Avatar
ditch the dot 3-4 fluid for some 5.1...you'll never worry about boiling while you're under heavy braking. i did the swap and never looked back
carving corners like a boss
Old 09-08-2013, 10:33 PM   #15
I've heard not to put 5 in our system BC it could cause it to fail? But dot 4 is fine
Old 09-08-2013, 10:34 PM   #16
1slosix's Avatar
you are correct never use dot 5 it is silicon based...however dot 5.1 is polyclycol based and is perfectly safe and is used for racing applications
Old 09-08-2013, 10:35 PM   #17
1slosix's Avatar
Dry Boiling Point Wet Boiling Point
DOT 3 401ºF 284º F
DOT 4 446º F 311º F
DOT 5 500º F 356º F
DOT 5.1 518º F 375º F
Old 09-08-2013, 10:35 PM   #18
you are correct never use dot 5 it is silicon based...however dot 5.1 i perfectly safe and is used for racing applications
What are the benefits and con's of it?
Old 09-08-2013, 10:36 PM   #19
1slosix's Avatar
pros...top performance in boiling point
cons...you have to buy it online since i haven't found any autoparts that keeps it on the shelf
Old 09-08-2013, 10:37 PM   #20
What about summit? I noticed they have a lot of brake fluid lol it's like an hour away from me
Old 09-08-2013, 10:38 PM   #21
1slosix's Avatar
that works...if you do the swap buy plenty..you'll have to fully bleed the old fluid out of the system ...so rent a vaccuum pump
Old 09-08-2013, 10:39 PM   #22
I might just pay someone to do that lol. That's something I don't want to f up
Old 09-08-2013, 10:45 PM   #23
andregayola's Avatar
If you use the 5.1 fluid with ss lines and hawk pads what kind of a difference should one expect going from stock
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 09-08-2013, 10:46 PM   #24
1slosix's Avatar
Lol its just time consuming but I see your point...new car might as well keep it on the up and up.
Old 09-08-2013, 11:16 PM   #25
Tyoung68's Avatar
Hell for 10k get a fox
Old 09-08-2013, 11:26 PM   #26
1slosix's Avatar
You'll feel like you're in a sports car finally. Best way I can put the feeling of being able to stop so well lol.
Old 09-08-2013, 11:36 PM   #27
Thanks because for some reason when im on the street my car stops like a champ but assoon as i get on the high way it gets all noisy and the pedal sinks all the way to the floor
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 09-09-2013, 12:07 AM   #28
Rileychan01's Avatar
Toyo R888/NT01 FTW
Rileychan01 is offline   Reply With Quote
Old 09-09-2013, 05:08 AM   #29
Hoosier race tires r6/a6 :p
Old 09-09-2013, 06:55 AM   #30
McQueen's Avatar
Only seen high hp car run this but none at the road course. Ur boss will be fine with stock cooling. I was also thinking about this if I ever go FI and track it but for now I see no need. It could also be illegal to run it as some events so I have to check into that
U would want the Hoosier R6 that are for the road course because the A6 are for autocross. Look that the sve from LMR they are awesome IMO for track 18x10.
Old 09-09-2013, 08:27 AM   #31
Tpost08's Avatar
I run a vmp tune and love it. But can't compare it to anything {•,•}
Tpost08 is offline   Reply With Quote
Old 09-09-2013, 08:30 AM   #32
I just emailed them about the SVE drifts. I like them but I have a feeling they are going to be heavy. I'm looking to stay as close to 20lbs per wheel as possible. 24-25 max
Old 09-09-2013, 08:53 AM   #33
McQueen's Avatar
The 18x10 sve are 22-24 pounds if I remember correctly. ALOT of people use it for the track.
Old 09-09-2013, 08:55 AM   #34
Do they fit the front fine? I'm looking to go 18x10 all around. Thanks for the info BTW
Old 09-09-2013, 09:00 AM   #35
McQueen's Avatar
They fit but u might need a spacer because it might rub with the brake cooling ducts.
07:10 AM
