A couple of guys were interested in my Bassani header installation, so I thought I'd make a thread on how I installed them.
I performed the install alone and on jack stands in my garage using the following procedure:
1. Secure the steering wheel in place using bungie cords.
2. Place the car on jack stands.
3. Loosen the two nuts on the flange plate where the steering shaft enters the car. Note: This will allow you to slide the steering shaft into the car to help facilitate separation.
4. Place floor jack under transmission to support engine and <acronym title="transmission">tranny</acronym>.
5. Remove k-member. Note: It's not necessary to remove the struts and rotors.
6. Remove motor mount brackets and factory headers with cats still attached.
7. Remove factory header studs and chase all bolt holes with a thread chase tool. Note: Clean all bolt holes with brake and parts cleaner.
8. Use new factory header gaskets.
9. Install aftermarket header. Note: I used the supplied bolts and anti seize.
10. Tighten all bolts evenly in a criss-cross pattern. Note: Tighten bolts from the center of the flange outward using a hand wrench.
11. Continue with options listed below or begin reinstalling previously removed parts.
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zps193d5414.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zpsfd2deddb.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zps894fe59f.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zps1c521344.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zps898ea8e1.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zpsc0844c5d.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zps8dc72fa2.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zpsee01774b.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zps4809ab5a.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zpsfa1d5fc0.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zpse9ac6d63.jpg
Optional mods to be performed while the k-member is out of the car:
1. Install new motor mounts.
2. Install front control arm bushings.
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zps297b2d2e.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zpsaab117a0.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zps2bb2a477.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zps244e1bde.jpg
http://i1351.photobucket.com/albums/p790/10HUTT/2013 Mustang GT/image_zpsdb01d1d9.jpg
