tuning issues - Mustang Evolution
Old 09-10-2013, 01:26 PM   #1
achiles85's Avatar
tuning issues
Has anyone with an aftermarket radio had problems tuning their vehicle?
achiles85 is offline   Reply With Quote
Old 09-10-2013, 01:49 PM   #2
I'm confused on why an aftermarket radio would cause any trouble tuning the vehicle... Why do you ask?
cstone94 is offline   Reply With Quote
Old 09-10-2013, 02:42 PM   #3
1lowGT's Avatar
Tuning isn't your problem.
Old 09-10-2013, 02:54 PM   #4
achiles85's Avatar
I recently tried updating my tune for some reason when I went back to stock the file didn't load and I ended up a blank ecm it was horrible...I want to put my updated tune on just nervous same problem will happen again
---------- Post added at 03:54 PM ---------- Previous post was at 03:51 PM ----------
Pcm
Old 09-10-2013, 04:58 PM   #5
Pcm
You aftermarket radio has nothing to do with this.
Which tuning device are you using?
Old 09-10-2013, 05:35 PM   #6
achiles85's Avatar
Intune
---------- Post added at 06:35 PM ---------- Previous post was at 06:33 PM ----------
I've used it before and had no problems and they worked really well with me when I called. I was just as to what couldve caused that to happen
Old 09-10-2013, 06:13 PM   #7
Intune
I would just give it another shot. Do what the tuner tells you to do; as far as turning the key to on and off. Post back if you have any troubles.
Old 09-10-2013, 10:37 PM   #8
Maverick2004054's Avatar
When you tune the coyote with a diabloSport tuner make sure you connect your car to a charger first! Many of the intune issues have come from low voltage during tuning! When my car was the test vehicle I lost access to my radio as well, after a few minutes on the charger and another go around everything was fine! Good luck and let us know what happens
Maverick2004054 is offline   Reply With Quote
Old 09-11-2013, 03:27 PM   #9
achiles85's Avatar
So I was able to put the tune on today not really sure what caused the issue the first time...thanks for the input guys
Old 09-14-2013, 12:33 PM   #10
DallasStang77's Avatar
There's some weird issues with tuners on my 13 Stang too.
9 out of 10 times my SCT tuner would fail when I return to stock. Well actually 6 of 7 cause I've retuned it that many times only.
Each time I would finally get it to work after letting it sit for an hour or two and let it reset. If I don't and try it after like 5-10 minutes it fails for sure.
So... I don't know why it fails but let it sit for a while and it should work. Stoopid SCT
Old 09-14-2013, 12:57 PM   #11
For some reason, unknown to me, there is a massive voltage drop on these cars when tuning, I played with mine yesterday and put a multimeter on it to watch after I fully charged the battery over night, initial voltage was 13.2 V removed the charger, during tuning voltage dropped to 11.6 V and after it was at 11.3 V. So the car has to be using a lot of power when wiping the tune and writing the new one onto the PCM...... I've never seen a drop like that before, my truck only drops 1.2 volts after a full charge then a tune.... So assuming people don't keep their cars on chargers the voltage drop is probably killing the tuning ability.... At least from what I have seen
Old 09-14-2013, 04:29 PM   #12
achiles85's Avatar
Honestly I think it was from not allowing the car to cool down enough. I read about other people having the same issue and the car thinks the heat is a problem during the tuning. Lesson learned lol
02:31 PM
