Steeda Now Offers Suspension Paks for 2011-2014 Mustangs - Mustang Evolution
Old 09-13-2013, 07:48 AM   #1
tj@steeda's Avatar
Hey Guys & Girls,
Gus has put together some great packages for your suspension needs. These combinations are going to take your car to that next level in regards to handling.
Check them out here:
http://www.steeda.com/store/ford-mus...sion-paks.html
Product Benefits
Limited LIFETIME Warranty!
Superior ride quality over any competitor
Greatly improved handling and cornering grip
Improved appearance and weight distribution
Reduced nose dive and body roll
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 09-13-2013, 08:48 PM   #2
smbeard's Avatar
Adjustable Panhard Bar
I noticed there is no adjustable panhard bar, or any camber correction. Will this kit still have you in factory alignment specs?
smbeard is offline   Reply With Quote
Old 09-16-2013, 09:39 AM   #3
tj@steeda's Avatar
In 90+% of cases you will still be within factory spec, and as long as you don’t have a staggered wheel/tire combo and you can rotate your tires when you are supposed to, you won’t have a tire wear issue. If you have staggered wheels and tires then you should get upper strut mounts and reduce the amount of negative camber.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
2014 mustang
07:23 PM
