Open filter?? - Mustang Evolution
Old 09-13-2013, 08:01 PM   #1
McQueen's Avatar
Open filter??
So a friend of mine has a paxton on his 5.0 without a filter just a mesh on the blower without the tube. Can this be bad? It does make the engine look so clean. Cons and pros please
Thank!
McQueen is offline   Reply With Quote
Old 09-13-2013, 08:32 PM   #2
Con-a new blower and motor are expensive
Pro-looks
Old 09-13-2013, 09:00 PM   #3
McQueen's Avatar
Pro-looks
But how can it be bad will the mesh be enough?
I have also seen a TT coyote do this.
Old 09-13-2013, 09:18 PM   #4
Dust does not combust. Not my motor being hurt.
Old 09-13-2013, 09:21 PM   #5
Black on Boss's Avatar
I'd have to see it but dust particles getting in that engine can't be a good thing :/
Old 09-13-2013, 09:22 PM   #6
08Mustang's Avatar
Awful idea
08Mustang is offline   Reply With Quote
Old 09-13-2013, 09:24 PM   #7
Originally Posted by 08Mustang View Post
Awful idea
That what I was thinking
Old 09-13-2013, 09:47 PM   #8
CorDog009's Avatar
Run a filter. Your rings will thank you.
'13 Deep Impact Blue GT, auto, BBK cat deletes, GT-500 A/B's, C&L tuned DiabloSport inTune, sound tube delete, BBK 85mm TB, JLT oil separator, NX plate kit.
CorDog009 is offline   Reply With Quote
Old 09-13-2013, 10:39 PM   #9
Rynarok's Avatar
I've seen this a lot (used to be big in the tuner crowd with my old SRT4). Not running a filter is usually a bad idea, but the thought process was that between the impeller and intercooler, most of the particles would be caught before they ever got into the combustion chamber. I'm not sure if I agreed with that logic, and I ran a filter....but it's not uncommon to see forced induction systems without it.
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 09-14-2013, 05:58 AM   #10
McQueen's Avatar
thanks guys, definably don't need a new motor so filter it is
Old 09-14-2013, 07:30 AM   #11
Screen/no filter on centris is worth about a pound in boost, give or take.
Wouldn't do it daily, but for track purposes they should be fine with screen.
Previous: '02 GT, '04 GT, '07 GT & a few chevys in between
'13 GT
Woodga16 is offline   Reply With Quote
Old 09-14-2013, 10:54 AM   #12
CorDog009's Avatar
Ever seen a few pieces of gravel go into the impeller? I had to figure out why a motor wasn't making any power...found out it had 1# of boost. Pulled the intake tube where there was no air filter, and gravel/small rocks had removed every fin off of the impeller, one small one was wedged in the housing just outside the impeller. The motor ate all the fins and whatever else made its way inside.
For the track, I'd run at least a screen. On the road, a filter.
03:47 PM
