exhaust help - Mustang Evolution
Old 09-30-2013, 08:15 PM   #1
Hbjatt13's Avatar
exhaust help
Hey guys, before you say "another exhaust thread" just read lol. So I've had my roush axle backs for around 3000 miles and they sound nice but way too raspy. So I want a catback and the best I could think on a budget was to get the heartthrob straight pipes and gt500's. After doing some research, turns out that the straight pipes have really bad fitment issues. What catback would you recommend that would be under or around 800$, that would be the loudest and deepest. I don't mind a little drone but if its to a point where I have to yell inside to car then I would just get some different axlebacks. Thanks for the help.
Hbjatt13 is offline   Reply With Quote
Old 09-30-2013, 09:12 PM   #2
2013_DIB_GTCS's Avatar
check out the Jeg's cat to axle kits. Very affordable and fitment was spot on. It's factory 2.75" piping.
2013_DIB_GTCS is offline   Reply With Quote
Old 09-30-2013, 09:16 PM   #3
Hbjatt13's Avatar
Thank for the reply, I was hoping for 3 inch piping. Do they carry 3 inch?
Old 09-30-2013, 09:20 PM   #4
That I don't know. I ordered the cat to axle kit without the resonators and it was 230 shipped. It said it was on special for like 80 bucks off. Couldn't turn that deal down. Borla and lethal performance want 350 for just over the axle pipes alone and the jegs kit comes with an H pipe. Not sure if it's offered with an x pipe.
Old 09-30-2013, 09:26 PM   #5
Hbjatt13's Avatar
Thanks, I checked and they do carry 3 inch. I might order one soon. Now i just need to find what axle back and h pipe to get.
Old 09-30-2013, 10:14 PM   #6
ThinBlueLine's Avatar
I have Lethal O/R H, Lethal Gen2 Over axle pipes and GT500's goin in tomorrow. look for the thread tomorrow. Should be pretty sick setup
BAMA TUNED
LETHAL O/R H, GEN2 OVER AXLE PIPES & GT500's
DRIVESHAFT SHOP ALUMINUM DS W/ BMR LOOP
MGW SHORT SHIFTER
CDC CHIN SPOILER W/ BLACK BILLET GRILLS
BLACK JLT OIL SEPARATOR
ThinBlueLine is offline   Reply With Quote
Old 10-01-2013, 02:27 PM   #7
Hbjatt13's Avatar
Ok I'll check it out for sure.
Old 10-01-2013, 04:46 PM   #8
BlackBetty5.0's Avatar
If you're not dead set on 3in piping just get the resonators cut out.
BlackBetty5.0 is offline   Reply With Quote
Old 10-01-2013, 04:58 PM   #9
Hbjatt13's Avatar
Yes I thought about that but I wanted to get better sound and better air flow.
Old 10-01-2013, 05:16 PM   #10
Thunder69's Avatar
I want the cat to axle as well to add to my Ford Racing sport axle back. I guess I need the 2.5 inch to do a direct bolt on
Thunder69 is offline   Reply With Quote
Old 10-01-2013, 05:19 PM   #11
Hbjatt13's Avatar
You can buy the 3inch cat to axle and it will fit.
Old 10-01-2013, 05:36 PM   #12
Thunder69's Avatar
Hmm. I thought there would be a problem since the current setup has 2.5 inch at cat and Axleback connections.
Old 10-01-2013, 05:42 PM   #13
Hbjatt13's Avatar
Call americanmuscle and make sure before you order
Old 10-02-2013, 08:38 PM   #14
Hbjatt13's Avatar
Are magnaflow competitions raspy with a offroad H?
Old 10-05-2013, 11:07 PM   #15
Yes. Straight through muffler designs with off road pipes will rasp.
BAMA TUNED
MGW SHORT SHIFTER
Old 10-06-2013, 05:04 AM   #16
Hbjatt13's Avatar
Went with the gt500 and jba off road H. Waiting for it to arrive.
Old 10-06-2013, 03:29 PM   #17
Lawrence's Avatar
If at all possible post a video! Thinking of adding an h pipe to my setup too.
Lawrence is offline   Reply With Quote
Old 10-08-2013, 12:09 AM   #18
DallasStang77's Avatar
Can an exhaust leak cause a ticking sound that's not too loud? It ticks with the same rhythm of the exhaust pulse. But just goes tick tick.
Doesn't make the sound at part throttle all the way up to say 6000rpm. Only when under load at least half throttle+. Also, revving the motor while parked makes no tick. Revved up flooring it all the way to like 5500-6000rpm. No ticks. No sound from engine bay except intake.
Driving next to the wall the ticking sound cant be heard at all. Window up trying to listen through the dash and firewall can't hear anything.
I think I've had this before after installing the straight pipes but wasn't too bad. But after installing the Boss IM it sounds just a bit louder.
Also if going only 40-45 mph and loading the throttle it makes a tick but adds a putt putt type sound so... Leak right?
Took it to an exhaust shop but said no leak. Tried searching exhaust leak acceleration under load on you tube but nothing clearly what I hear. Not likely lifter or cam cuz idles fine. No clacking on parked rev.
Old 10-08-2013, 12:21 AM   #19
Hbjatt13's Avatar
That's weird! If an exhaust shop said that its not a leak then take it to another exhaust shop and have them check as well. Do more research I've read a few places about that ticking noises.
Old 10-08-2013, 12:36 AM   #20
Also a weird thing is making a right turn and loading it makes the sound louder. I'm thinking weight shift causing the pipes to flex more than just going forward because the engine is shifting a bit laterally against the mounts.
Damnit I guess I'm heading up to another exhaust shop along with a bottle of soapy water and not leaving until the spray it down with suds.
Old 10-08-2013, 12:39 AM   #21
Hbjatt13's Avatar
Or try the dealership they might play nice and help lol
Old 10-08-2013, 04:39 AM   #22
Clink's Avatar
Any chance if a video of this setup yet?
Old 10-08-2013, 05:46 AM   #23
I'll do the video this weekend. Don't have a camcorder just my phone. Taking her into the body shop today for the bumper repair she suffered from getting rear ended last week. Hope they don't take her for a joyride. If they do hopefully they'll properly warm her up.
Any ideas on joyride prevention techniques?
Old 10-08-2013, 07:30 AM   #24
tc x 4's Avatar
Smith & Wesson
Old 10-08-2013, 08:12 AM   #25
Originally Posted by tc x 4 View Post
Smith & Wesson
Gun or knife?
Old 10-08-2013, 08:16 AM   #26
tc x 4's Avatar
Gun or knife?
Both, just depends on how personal you wanna get.
01:04 PM
