how do I get my stock mufflers off? - Mustang Evolution
Old 10-03-2013, 03:28 PM   #1
With aftermatket exhausts ive just un bolted the hangers and it was a breeze. The stock mufflers dont allow clearance to get to these bolts though. Is there a way to get the mufflers off without loosening the mid pipe? I dont have ramps to do that. Any help would be appreciated.
Mikeyt03 is offline   Reply With Quote
Old 10-03-2013, 06:06 PM   #2
CorDog009's Avatar
Mine unbolted easily. Loosen the bolt on the ball/socket clamp and pull the hanger out of the rubber isolator.
'13 Deep Impact Blue GT, auto, BBK cat deletes, GT-500 A/B's, C&L tuned DiabloSport inTune, sound tube delete, BBK 85mm TB, JLT oil separator, NX plate kit.
CorDog009 is offline   Reply With Quote
Old 10-03-2013, 06:21 PM   #3
Doe_Rae_mi's Avatar
^Yes
Old 10-03-2013, 06:28 PM   #4
Missouri Hoss's Avatar
Before you start, it helps greatly if you'll WD-40 the hanger rods/rubbers so the mufflers slide easier.
I pulled my OEMs without loosening any hanger brackets. I did pull the bolts and dropped the panhard bar on the drivers side for clearance, and jacked the midpipes up against the floorpan for removal of both mufflers. I also fully opened and folded both pipe clamps back as far as they'd go to allow midpipe flange clearance.
Missouri Hoss is offline   Reply With Quote
Old 10-03-2013, 06:28 PM   #5
Hmm. Maybe I need to try again.
Old 10-03-2013, 06:33 PM   #6
I just gritted my teeth and pulled and shoved until they came off. Installation was a piece of cake. I installed Heartthrob Flowpacks.
Old 10-03-2013, 06:39 PM   #7
2 Stangz's Avatar
Region: Nevada
Yep. Stockers come right off with aforementioned advice.
Old 10-03-2013, 06:44 PM   #8
One thing I forgot to mention... I thinly wrapped the muffler tips with rags and taped them to guard against paint scars and scratches.
Old 10-03-2013, 06:55 PM   #9
2 Stangz's Avatar
Region: Nevada
Also a good idea. I happened to have a giant roll of bubble wrap around so I used that instead.
Old 10-03-2013, 07:00 PM   #10
DWC_SmOziLLa's Avatar
It's even easier if you unbolt the hangers. No struggling at all.
Old 10-03-2013, 07:34 PM   #11
Yep! Thats what I want to do, but the oem mufflers dont have enough clearance to let me. Hmm...ive got to be missing something. How did u get the hangers off with the oem mufflers on?
Old 10-03-2013, 07:41 PM   #12
KARgt13's Avatar
Slide the mufflers off the hangers at the very rear of the car, then you can get to the other bolts. You might have to drop the panhard bar brace to help.
KARgt13 is offline   Reply With Quote
Old 10-03-2013, 07:43 PM   #13
Tpost08's Avatar
Install instructions on am are pretty straight forward as far as easiest way to do it (tells you how to get oem mufflers off). I know on my 2012. It was also tack welded. So you gunna have to break that unless the newer models don't have that.
Tpost08 is offline   Reply With Quote
Old 10-03-2013, 07:44 PM   #14
Jcav58's Avatar
I did mine in about 30 mins. The panhard bracket will have to b loosened to do the driver side
Jcav58 is offline   Reply With Quote
Old 10-04-2013, 08:05 AM   #15
Strange Mud's Avatar
note the clamps (on mine anyway) were welded to the mufflers...I loosened them then took the hanger bolts off and removed the hangers and mufflers together. PB Blaster on the clamp bolts & silicone on the hanger bushings.
I will suggest cursing a bit too.
edit, mine was the V6
Old 10-05-2013, 02:48 PM   #16
Holy crap i was sore the next day from trying to pull the hangers off, ultimately i gave up and realised i could drop the whole bracket down easier which made things much easier.
2013 GT Premium MT82
Air Raid CAI, GT500 Axleback, Tune, GT500 style wheels, FR GT500 struts, 1" drop springs
Exturbo is offline   Reply With Quote
02:21 AM
