Best fluid for MT82 - Mustang Evolution
Old 10-05-2013, 03:21 PM   #1
s1975OH's Avatar
Best fluid for MT82
Im looking to try a different fluid with hopes of some kind of improvement, I plan on keeping the OEM stuff to cover myself if the transmission decides to explode, I would like to hear which fluids people have had luck with
13 GT Premium 3:73 JLT Boss IM Lethal OR/X Ford Racing Mufflers
s1975OH is offline   Reply With Quote
Old 10-05-2013, 09:51 PM   #2
Amsoil MTF.
Budwise is offline   Reply With Quote
Old 10-12-2013, 08:56 AM   #3
Darkside's Avatar
Hey as soon as I got the car, I put royal purple syncro max
Darkside is offline   Reply With Quote
Old 10-12-2013, 09:21 AM   #4
striker79's Avatar
I did the same.
Yellow Blaze 2011 Mustang GT Premium. Kooks 1 7/8 midlength headers, Kooks Boss 302 H-pipe with Kooks sidepipes. Heartthrob mid pipes with flowpacks. RTR axle backs. Vogtland lowering springs. BMR adjustable panhard bar. Boss 302 Brake duct kit. Boss 302 trans scoop. Boss 302 oil cooler. Boss Intake Manifold. BBK 90mm Throttle Body. JLT Cold air intake with bama tune. JLT oil separator. Steeda lower control arms. BMR control arm relocation brackets. Barton two post short shifter. DSS Aluminum drive shaft. ACT HD Twin Disc Clutch
striker79 is offline   Reply With Quote
Old 10-14-2013, 10:12 AM   #5
Region: Vermont
Send a message via AIM to GBlueGT
Did you all notice a difference by changing out the factory fluid?
Rob
GBlueGT is offline   Reply With Quote
Old 10-14-2013, 11:02 AM   #6
s1975OH's Avatar
I put amsoil MTG in, I'd say there's a difference
Old 10-14-2013, 11:18 AM   #7
Darkside's Avatar
Rob
Yes, deff
Old 10-14-2013, 04:51 PM   #8
FastFord13's Avatar
I did the same also.
Old 10-14-2013, 05:05 PM   #9
bigsmitty24's Avatar
What kind of difference? Just curious.
bigsmitty24 is offline   Reply With Quote
Old 10-14-2013, 05:15 PM   #10
Darkside's Avatar
Shifts r smoother. And it protects your syncros which r known to fail in our stangs
Old 10-14-2013, 08:50 PM   #11
Black on Boss's Avatar
Yes they are lol
Old 10-14-2013, 08:51 PM   #12
FastFord13's Avatar
Yes they are lol
+1
Old 10-14-2013, 09:31 PM   #13
Stang8psi's Avatar
Region: Delaware
Also the type of fluid depends on the users climate.. amsoil mtf for colder northern climates.. And the MTG for southern or warmer/hotter climates.
Stang8psi is offline   Reply With Quote
Old 10-15-2013, 08:35 PM   #14
ddtmoto's Avatar
Region: Utah
I went with Redline MTL. Has anyone added the XL18 on top of Redline or Amsoil?
ddtmoto is offline   Reply With Quote
Old 10-16-2013, 07:00 AM   #15
Trans fluid
Ford dual clutch fluid and the XL18 additive have worked very well in my trans. Seems like Ford finally worked it out.
shottist is offline   Reply With Quote
Old 10-16-2013, 07:57 PM   #16
I keep seeing multiple different kinds of fluids being mentioned and lots of forums. The basic description you get is made the trans shift smoother. Is there more technical information on which fluid is better? i.e. Temp reduction, viscosity v temp?, lubrication factors?, additives?
laxmunkey26 is offline   Reply With Quote
Old 10-16-2013, 09:35 PM   #17
ThinBlueLine's Avatar
How many QTs of MTG would one need for a 2012 5.0?
BAMA TUNED
LETHAL O/R H, GEN2 OVER AXLE PIPES & GT500's
DRIVESHAFT SHOP ALUMINUM DS W/ BMR LOOP
MGW SHORT SHIFTER
CDC CHIN SPOILER W/ BLACK BILLET GRILLS
BLACK JLT OIL SEPARATOR
ThinBlueLine is offline   Reply With Quote
Old 10-16-2013, 09:45 PM   #18
gtstyles2's Avatar
It's in the manual, the V6 and the GT are filled differently... On the GT u can't just keep adding fluid until it drips out, u have to precisely add 2.7 qts
ID:	132812   Click image for larger version
Old 10-17-2013, 09:35 PM   #19
Amsoil no longer recommends MTG at all for the MT82. MTF only.
Old 10-22-2013, 11:03 PM   #20
Forgive my for my lack of education but what is MTG & MTF?
Old 10-25-2013, 08:13 PM   #21
Stang8psi's Avatar
Region: Delaware
mtg ( Manual Transmission & Transaxle Gear Lube 75W-90) Mtf ( Manual Synchromesh Transmission Fluid 5W-30)
Old 10-26-2013, 04:03 AM   #22
2013fiveO's Avatar
Can you show us where you got that info? I switched to MTG a few months ago and it is running great. However if I were to see that from Amsoil I would change it again.
2013 GT 6MT, 3.31s, Brembo Pckg, Sync
Mods: AED Tune,Boss 302 IM, BBK 85mm TB,Kooks SS Shorty Headers,HF Cats,Alum 1pc DS,Hotchkis Subframe Connectors,Steeda CAI,Roush Axlebacks,Barton Shifter,SR Clutch Line,Boss Oil/Trans Coolers,SVT Fan,Steeda Sport Springs/LCAs/UCA/Shifter Bracket/HD Motor Mounts,BMR LCA Relo Brackets,Koni Shocks/Struts,GT500 Strut Mounts,JLT Oil Sep,Hood Struts,GT500 Spoiler,MMD Taillight Trim,OEM Leather Seats,MT Street Comps on black AMRs,MT ET Street Radial IIs on black Bullits(track duty).
2013fiveO is offline   Reply With Quote
Old 10-26-2013, 12:43 PM   #23
From the svtperformance.com forums, PM's between him and myself. UnleashedBeast is an Amsoil rep. If you search you'll find plenty of forums he's on and he states that Amsoil now recommends only MTF, not MTG. MTG is too viscous and causes notchiness on cold starts and in cold climates. It was previously OK'd for hotter/southern climates but now they recommend MTF across the board. Mine has been doing great with MTF thus far here in Texas. Hope this helps!
Originally Posted by UnleashedBeast
No, look at the dates...Ford back spec'd the fluid from 75W-90 to a very light synchromesh. It was a drastic change. You will be perfectly fine with MTF.
I noticed in some threads that i read you were recommending the MTG over the MTF for road course or hot climate. I am doing road course in Texas soooo, should i go MTG or MTF?
First, thanks for being such a wealth of information on these forums. I enjoy your scientific approach and analysis.
My question must be prefaced by the following:
2013 GT w/ Brembo, I installed the Boss Oil Cooler myself, the engine is on stock tune and un-modded, only suspension mods are done.
I'm taking it to the track (road course, 20 minute sessions, 4 sessions a day for 2 days) in October and I live in Texas where its damn hot. I've been running Penzoil Ultra 5W-30 for daily use. Should I bump up to a 10w-40 for the track or should I stick to the PU 5w30?
Thanks for your response and what you do here.
The thing to remember is, how hot the oil is getting around the piston. It can reach temps up to 300*F, and bring disaster to cheap engine lubricants during extended road racing events.
HT/HS (High Temp / High Shear) is the term we use to measure a lubricants viscosity at 150*C (300*F). This simulates viscosity when it's around the piston areas of the engine. 30 grade lubricants are around 3.2, while 40 grade lubricants are in the 4.3 range. The higher HT/HS is desired during long session road course events to protect cylinder piston ring to piston wall contact.
For your use, I'd recommend increasing viscosity in the engine. There is a reason why Ford recommends higher viscosity in Track Pack GT and Boss 302 engines, they know it will be used for extended session events.
The oil cooler will help control overall oil temps, but even the Boss 302 requires more viscosity during these events.
Amsoil AMO 10W-40
Amsoil EaO17 oil filter
You will want this in your transmission, in case that you are not using it already.
Amsoil MTF Synchromesh - requires 3 quarts
Hand Pump - makes it easy to get new fluid into your transmission
Want the best protection for your rear axle? Road racing is punishing.
Amsoil Severe Gear 75W-140 - requires 3 quarts
Amsoil Slip Lock - requires 1 bottle
When you are not going track crazy, it's perfectly fine to step down to Pennzoil Ultra 5W-30 again, or for mpg increases....
Amsoil AZO 0W-30
and please, do not pay cost on this stuff.
Preferred Customer
Troy
Old 10-26-2013, 01:11 PM   #24
Thanks for all the info Budwise
Old 08-30-2014, 07:53 AM   #25
Getn off's Avatar
Yes I know this is an old thread. I actually want to talk to peeps that have swapped out Ford's fluid and put miles on the mt-82. Amsoil's website says that they do not recommend using any of their products on the mt-82. Can't get a definitive answer from royal purple or redline.
So, how are ur tranny's holding up with ur fluid now? Did it get notchy again? Any problems yet?
I want to swap out, but not sure what to use now.
Troy
Getn off is offline   Reply With Quote
Old 08-30-2014, 09:58 AM   #26
WJBertrand's Avatar
Mine is working pretty well with Red Line MTL and the Ford XL18 additive. Got around 9K on that combination now. Note I've also fitted an MGW shifter.
-Jeff-
STOC 025
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 08-30-2014, 06:41 PM   #27
Getn off's Avatar
Thx jeff. R u having any issues at all? Feeling notchy?
Troy
Old 08-30-2014, 11:52 PM   #28
WJBertrand's Avatar
It's a little notchy on the 1-2 shift but fine everywhere else. Hoping the blowfish racing shifter bracket addresses that last little bit.
-Jeff-
STOC 025
-Jeff-
Ventura, CA
Old 08-31-2014, 12:15 AM   #29
Amsoil won't make a recommendation because of the history with the MT-82. However, many people are using MTF with good results. I switched to MTF at approximately 4000 miles, and have 8000 miles now with good results. Overall shifts are easier and smoother. There is still the occasional notchiness into second, but its much improved.
I added the Barton 2 post shifter bracket and Whiteline lower transmission mount at the same time. While these two parts made the most improvement during high RPM hard shifts, at lost speed casual shifting I can feel the impact the fluid has. Overall after switching to the Amsoil fluid everything feels more refined. Its not perfect, but is a definite improvement.
I have not driven the car in cold weather with the new fluid. Its still hot in Texas. My opinion could change this winter.
The MT-82 originally came with a thick 14cSt fluid. They then switched to a thin 6-7cSt fluid in the 2012 model year. They then later added the XL18 additive. They later still stopped using the XL18 additive.
The one thing people seem to agree on is that the MT-82 likes a fluid on the thinner side. When I made my fluid choice, I went with MTF because it was a relatively thin fluid fluid at 9-10cSt, that still offered adequate protection in Texas heat. I also had good success with it in my previous vehicle, which also had notchiness during shifts.
But there are numerous fluids that people have had good success with, so use what you can easily get locally.
Good luck!
BadCon is offline   Reply With Quote
Old 08-31-2014, 10:42 PM   #30
Getn off's Avatar
Appreciate the comment. Ty.
Troy
Old 09-01-2014, 08:46 AM   #31
Pony_Boy's Avatar
Shouldn't any fluid meeting the Ford spec work? I think the RP Synchromesh meets it, spec attached
Name:	ImageUploadedByMustang Evolution1409582781.115303.jpg
You know that warm and fuzzy feeling? That means something bad is about to happen...
Pony_Boy is offline   Reply With Quote
Old 09-01-2014, 05:32 PM   #32
Getn off's Avatar
If it meets those specs, then yes. But I am not sure what does. I cannot find where rp, or redline specifically state it will. Amsoil specifically states no.
The hunt continues!
Troy
Old 09-01-2014, 08:01 PM   #33
Pony_Boy's Avatar
The hunt continues!
Troy
Well, here is RP recommendation PDF with the XT-11-QDC listed as the Synchromax, should be
OK. They even state it's for MT that spec ATF fluid like the dual clutch stuff Fords putting in.
http://www.royalpurpleconsumer.com/a..._Reference.pdf
Old 09-01-2014, 08:06 PM   #34
FastFord13's Avatar
I've been using RP for over a year in my 13 manual.
2013 3.7 Manual Candy apple red metallic,
GT 500 stripes, painted side mirror covers, GT 500 spoiler, 2010 GT premium wheels with Pirelli P-zero tires, upper and lower front billet grille, Barton shifter bracket, Airaid Cold air intake, S.R lowering springs, J&M adjustable panhard bar, Boss 302 strut tower brace, 3.73 ford racing gears, Bama tuned, BBK shorty headers, Roush Axel backs.
Old 09-02-2014, 05:28 PM   #35
Getn off's Avatar
Thx guys.
I think pony found what I have been hunting for. Looks like it is Synchromax for me.
Still curious what happened over at Amsoil!
Troy
08:51 PM
