Cylinder 3 misfire - Mustang Evolution
Old 10-14-2013, 05:40 PM   #1
ItzSLash's Avatar
Cylinder 3 misfire
Just got a P0303 code. The engine has been stumbling and finally it coughed up a code. I'm thinking coil, I heard I can switch the wires from one cylinder to another just to check if it's that coil. The wires don't seem long enough but I'm gonna try it. Just wanted to make sure it won't cause problems.? Also I'm thinking it was bad gas that effected an injector. Any thoughts?
ItzSLash is offline   Reply With Quote
Old 10-15-2013, 03:44 PM   #2
Darkside's Avatar
Have you gotten gas from somewhere you think is shady?
Darkside is offline   Reply With Quote
Old 10-15-2013, 04:12 PM   #3
ItzSLash's Avatar
No. But I put in 87 a few times by accident but that was a while ago. Since then I have made sure I only get 91. And since the problem started I put octane boost to help burn up all the crap. I've also reset the idle.
Old 10-15-2013, 04:30 PM   #4
Grabber Blue5.0's Avatar
Are you tuned? Stock?
Old 10-15-2013, 04:43 PM   #5
ItzSLash's Avatar
Stock
Old 10-16-2013, 12:02 AM   #6
Charlie_santos's Avatar
Never use a octane booster those things are terrible for your motor. Try a different gas a good one. I personally only use Shell V-Power or Cheveron with Tectron stuff.
Old 10-16-2013, 12:23 AM   #7
Rapinator126's Avatar
Torco is a good octane booster. But you have to be tuned for it
Old 10-16-2013, 06:48 AM   #8
Darkside's Avatar
What happens if u put torco in a stock car
Old 10-16-2013, 08:38 AM   #9
The motor can adjust uts timing for higher octane if you measure exactly enough torco needed for say maybe 95 octane thats really all the timing it can be adjusted if you just poured a ****tload in ur tank u better f*cken drain ur tank. That torco is good but can turn gas into 115 octane race fuel which a stock car cant handle at all!
Old 10-16-2013, 08:41 AM   #10
Darkside's Avatar
Understood, thanks. No I have it and haven't put it in yet. I'll prob put 1/8th the bottle. I was really only doing it for a cleaner burn for the engine.
Old 10-16-2013, 09:02 AM   #11
I ONLY use it at the track and make my gas 95 octane for my 93 octane tune. I also asked my tuner to see if the tune even if tuned for 93 if 95 would be okay he said its the max I coukd go without requiring a new custom tune for more. Just be careful with torco bro. Ive read forums where the person messed stuff up by unknowingly pouring it in and yea u know where im getting at.
Old 10-16-2013, 09:08 AM   #12
Darkside's Avatar
Thank you bro. Maybe I'll just hold off.
Not worth it
Old 10-16-2013, 09:37 AM   #13
Not worth it
Yea bro just play it smart. Id start by running through ur tank and try filling up with 91 from shell or chevron bro and burning that tank and redoing it again. That will rule out the gas issue.
Old 10-16-2013, 09:44 AM   #14
Darkside's Avatar
Yeah I don't want to take chances. I've already made a leap to change oil from 5w50 mc to 10w40 RP hps. Still shaky about it
Old 10-16-2013, 11:53 PM   #15
I stick with whats on my oil cap...but idk your weather etc so u may need that thick weight who knows
Old 10-17-2013, 08:16 AM   #16
ItzSLash's Avatar
Found the problem. The coil boot is split and it's arcing to the block.
Old 10-17-2013, 12:46 PM   #17
Darkside's Avatar
What's on the cap varies so much. Most cars they say out 5w20 but actually 5w30 is better for the car. I have the exact same engine and I put 5w50? Because the expect me to track it. Which I won't do. I have to use my judgment to safe guard my engine.
11:55 AM
