Ad Back up camera to Sync system 2011 GT - Mustang Evolution
Old 10-19-2013, 05:58 PM   #1
Ugabrick's Avatar
I have a 2011 GT 5.0 with the sync system. My system includes navigation and shaker audio but no back up camera. My wives ford fusion sport 2011 has the sync with the camera. Has anybody added one to their mustang and is it easy?
Ugabrick is offline   Reply With Quote
Old 10-19-2013, 06:29 PM   #2
Not much of an expert in this area... But i'm sure this could work
Mustang Rearview Back-Up Camera License Plate Frame (79-14 All) - Free Shipping VTL120
Old 10-19-2013, 06:33 PM   #3
Ugabrick's Avatar
Thanks brother, I have a camera in mind that goes in the actual space between the tag lights. Just wanted to see if anyone else had done it. Thanks again
Old 10-19-2013, 07:12 PM   #4
The unit itself has the capability, you just have to find a camera that will hook up... My guess is that most will be universal also.
Old 10-19-2013, 09:50 PM   #5
Try this one .....
http://www.americanmuscle.com/raxiom-gps-nav-1014.html
El Fufi is offline   Reply With Quote
Old 10-19-2013, 09:55 PM   #6
Fender868's Avatar
He already has the sync touch screen navigation. He couldn't install this anyways since the ac controls are different on models with the touch screen sync navigation unit.
Fender868 is offline   Reply With Quote
Old 10-20-2013, 06:42 AM   #7
Ugabrick's Avatar
Thanks but fender is right, I only need camera and sensors hooked to my existing system and monitor. I also think while I'm in there install a bypass so the sync navigation and DVD player can be used going down the road.
Old 10-20-2013, 10:16 AM   #8
Fender868's Avatar
I'm pretty sure you can purchase the camera spoiler from ford with the camera and then all you would have to do is wire to your head unit. Pretty simple install, and really, it would be the cleanest install. I have the back up camera on mine and while it's not a need to have item, i certainly appreciated for those first couple days of awkward parking when you're not entirely familiar with your cars dimensions. It's extremely cool for parallel in tight spots . No need to second guess where your *** is, you can just get in there as closer as pupils need.
Old 10-21-2013, 08:49 AM   #9
i got NavTool.com + pioneer camera
blackonsilver is offline   Reply With Quote
Old 10-23-2013, 09:44 AM   #10
I posted my camera install with picture on here some time ago. I used a Echomaster VM150 that I mounted under the spoiler (which Ford said couldn't be done) and it was fairly straightforward. The left support post on my GT/CS had a hole provided from factory that merely needed the hollow spoiler drilled to match. I built a custom wedge to provide the needed angle of view and wired into the reverse lamps while tying into factory harness for the video.
mtnman325 is offline   Reply With Quote
2011 gt
08:59 PM
