X or H pipe... - Mustang Evolution
Old 10-21-2013, 03:06 AM   #1
Kona Mike's Avatar
X or H pipe...
I go with Gt 500 mufflers? What's got the sweetest sound? Brands?
Kona Mike is offline   Reply With Quote
Old 10-21-2013, 08:43 AM   #2
Sakol's Avatar
Had to contend with CA emissions standards as this is my DD. So I got ford x pipe with borla catback S type exhaust. I didn't go ATAK because it would be too loud and didn't go with Touring because it wouldn't be loud enough.
ID:	133293   Click image for larger version
ID:	133300   Click image for larger version
ID:	133302   Click image for larger version
Sakol is offline   Reply With Quote
Old 10-21-2013, 09:26 AM   #3
Kona Mike's Avatar
Thanks. But I'm looking for the best match with Gt500's. Plus, I have no emissions to contend with. Resonators will be removed as well.
Old 10-21-2013, 09:31 AM   #4
Adogg's Avatar
It's really up to you what you like better, I personally like h pipes, I would recommend looking up videos on YouTube
Don't hate....... appreciate
Old 10-21-2013, 10:32 AM   #5
Lawrence's Avatar
I'll let you know in the next two days. My H pipe is coming in and I have gt500 axlebacks with resonators removed.
An H pipe is supposed to make the exhaust note deeper, while the X pipe will make it higher pitched and "raspier"
As for performance gains, the H pipe makes slightly less power than an X pipe. Because it is so minimal you're better off making the sound a priority over the power gains.
Lawrence is offline   Reply With Quote
Old 10-21-2013, 11:06 AM   #6
I have a prochamber... It is a little quieter than the H and X pipes, but it sounds freakin' amazing. It is quiet around town (quiet to mustang guys, people still hear me before they see me). But when you get on it, it screams.
Old 10-21-2013, 12:37 PM   #7
2013Coyote5.0's Avatar
I just got my resonators cut out, gt500s, lethal o/r x. Wouldn't trade the sound of my exhaust for the world. I'll post a vid tonight
2013Coyote5.0 is offline   Reply With Quote
Old 10-21-2013, 01:13 PM   #8
Kona Mike's Avatar
Please do.
Old 10-21-2013, 03:31 PM   #9
ThinBlueLine's Avatar
I've got the gt500's with lethal over axle pipes and lethal o/r H. Zero drone anywhere in the rpm band, no rasp and growls when I get on it. Perfect.
BAMA TUNED
LETHAL O/R H, GEN2 OVER AXLE PIPES & GT500's
DRIVESHAFT SHOP ALUMINUM DS W/ BMR LOOP
MGW SHORT SHIFTER
CDC CHIN SPOILER W/ BLACK BILLET GRILLS
BLACK JLT OIL SEPARATOR
ThinBlueLine is offline   Reply With Quote
Old 10-21-2013, 07:12 PM   #10
I have JBA longtubes and at first I had the JBA H-pipe for about 6 months then I bought the JBA x-pipe and not only does it sound better but I gained a little hp, oh and yes I have the gt500's , the gt500's are the only muffler that I know of that you can run H or X pipe and no cats and no resonators without any rasp...
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 10-24-2013, 12:19 PM   #11
Lawrence's Avatar
Did anyone hear have a leaking issue with the JBA H pipe? Had mine done today and it's leaking a little. I've got the cats on still. I think it's coming from passenger side and/or the part where the H pipe connects in the middle.
Old 10-24-2013, 12:41 PM   #12
I have the same pipe, but you have to seriously fiddle with it to get the fitment correct. Try pulling on your over axle pipes to get them as close as you can and tighten them up as much as possible. Then push the h-pipe right at the H with your foot towards the front of the car and tighten it up as best you can. That's what I did.
Old 10-24-2013, 01:57 PM   #13
mine never leaked but I tightened the heck outta that clamp, it is kinda cheesy how that H pipe from JBA is, but for the money its well worth it....
Old 10-24-2013, 03:08 PM   #14
Lawrence's Avatar
It's all fixed now guys, thanks!
Old 11-07-2013, 08:57 AM   #15
H pipe if you love that deep classic mustang sound! Both are still awesome either way though.
Jshadow is offline   Reply With Quote
Old 11-21-2013, 12:49 PM   #16
Here's the vid...late response I know lol.
01:06 AM
