Cutting out - Mustang Evolution
Old 10-23-2013, 04:40 PM   #1
sleeperstatus's Avatar
Cutting out
Hey guys my car under acceleration speeds up and has like pause/cut out/dies then picks back up after what could this be? Only happens during hard acceleration. Drives normal all other times
Thanks for the help.
sleeperstatus is offline   Reply With Quote
Old 10-23-2013, 04:57 PM   #2
2013Coyote5.0's Avatar
Originally Posted by sleeperstatus View Post
Hey guys my car under acceleration speeds up and has like pause/cut out/dies then picks back up after what could this be? Only happens during hard acceleration. Drives normal all other times Thanks for the help.
Could be your traction control kicking in because you are spinning. Have you tested it with the tc turned off?
2013Coyote5.0 is offline   Reply With Quote
Old 10-23-2013, 05:26 PM   #3
86 muscle's Avatar
My guess almost verbatim.
86 muscle is offline   Reply With Quote
Old 10-23-2013, 05:34 PM   #4
2013_DIB_GTCS's Avatar
Mine does the same thing with traction control on. I usually drive with it off unless the road conditions are bad. Never had this happen with traction control off
2013_DIB_GTCS is offline   Reply With Quote
Old 10-23-2013, 05:40 PM   #5
Jcav58's Avatar
Sounds like it is hitting the rev limit
Jcav58 is offline   Reply With Quote
Old 10-23-2013, 05:44 PM   #6
Auto or manual?
Old 10-23-2013, 06:51 PM   #7
dobypaw3's Avatar
+1
dobypaw3 is offline   Reply With Quote
Old 10-23-2013, 08:45 PM   #8
It's not rev limiter and not traction because it can happen rolling in 4th gear and it like between 4000 to like 5500 rpm
---------- Post added at 10:45 PM ---------- Previous post was at 10:45 PM ----------
My car is also manual
Old 10-23-2013, 09:20 PM   #9
It's not rev limiter and not traction because it can happen rolling in 4th gear and it like between 4000 to like 5500 rpm ---------- Post added at 10:45 PM ---------- Previous post was at 10:45 PM ---------- My car is also manual
Then it's probably fuel related.
Old 10-23-2013, 09:55 PM   #10
I was thinking an injector problem
Old 10-25-2013, 03:46 PM   #11
Bump
Old 10-27-2013, 09:27 PM   #12
Had a similar issue when in tried to run 87 in my car.
laxmunkey26 is offline   Reply With Quote
Old 10-28-2013, 12:20 AM   #13
I have only ever put 93 in my car
Old 10-28-2013, 02:49 AM   #14
Black5.0's Avatar
It's tc, did it in 4th at the track in my car when I first got it. Happened twice and I didn't know what the f was going on. Thought I turned tc off but turns out I was in sport mode. Once I turned it completely off it never did it again.
Black5.0 is offline   Reply With Quote
11:32 PM
