Rear gear install - Mustang Evolution
Old 10-24-2013, 09:07 AM   #1
Rear gear install
I have a 13 GT with stock 3.31 gear. I have a used 3.73 to put in it. My question is: is the rear end the same as all other Ford 8.8 rear ends? So nothing different in install than any other year?
Ian13 is offline   Reply With Quote
Old 10-24-2013, 10:07 AM   #2
Pretty much the same with the exception of the pinion bearing, not 100% sure tho, you would want to put new bearing in anyways I would think..
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 10-24-2013, 10:14 AM   #3
Ok good, just didn't want some shop trying to shaft me saying it's newer and different so charge more. I try to do most stuff myself but I don't know anything bout setting backlash and all that mess so if rather have someone do it right.
Old 10-24-2013, 10:45 AM   #4
How old are the gears? what yr car were they out of? it looks like they may be diff. in 09 and earlier?
Old 10-24-2013, 11:08 AM   #5
Crap, I've had them for awhile and never got round to putting them in last mustang so I don't know but prolly older than 09..... I thought they all 8.8 rear end and the same.
Old 10-24-2013, 11:36 AM   #6
tc x 4's Avatar
They will work.
Old 10-24-2013, 11:48 AM   #7
Great, preciate it. I sure hope so
Old 10-24-2013, 12:30 PM   #8
Site Sponsor
Sponsor
AMWill's Avatar
They should work with no problem. The only difference is the larger pinion bearing needed. Here's a link to the pinion bearing you'll need to replace, since it's pressed onto the pinion.
Good luck with the install. Let me know if you have more questions!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 10-24-2013, 02:33 PM   #9
Grabber Blue5.0's Avatar
Shane
Actually wrong Shane. The older style pinion bearing can be used.
Old 10-24-2013, 02:39 PM   #10
mystang50's Avatar
somones about to get banned from shopping at American muscle
Old 10-24-2013, 03:18 PM   #11
Yea I'll take that chance.
But I did have to set the record straight.
Old 10-25-2013, 02:48 PM   #12
Site Sponsor
Sponsor
AMWill's Avatar
I did make one mistake in my post. I should have said- "the only difference is the *smaller or more concave* pinion bearing needed." Which is true.
I think you're forgetting the OP only has a ring and pinion set that was used on an 86-09 8.8 rear end. Although the 86-09 bearing will fit in the 10-14 8.8 housing. The OP most likely doesn't have the 86-09 pinion bearing race to go with his old bearing. It's not wise to use his factory 2013 pinion race with the 86-09 pinion bearing, as they won't seat properly and will cause a failure.
Of course, if the OP does indeed have old 86-09 bearing race, he can install the setup in his 10-14 8.8 housing. I also want to note- bearing's wear/form to each other over time/heat. I wouldn't purchase a new 86-09 bearing race to mate with a used 86-09 bearing. There's a chance you won't have a problem, but why risk it at that point?
Hope this helps clear things up!
Shane
« mt82 | Gear whine »
07:33 PM
