Bama tune octane question - Mustang Evolution
Old 10-27-2013, 11:48 AM   #1
I've asked this before but have lost the answer.
Is an 87 octane Bama tune beneficial cost/performance wise over the factory tune using 93 octane ?
Thanks.
larietrope is offline   Reply With Quote
Old 10-27-2013, 11:50 AM   #2
1lowGT's Avatar
Yes
---------- Post added at 12:50 PM ---------- Previous post was at 12:50 PM ----------
Factory tune with 93 serves no purpose it's just wasting money really.
Old 10-27-2013, 11:58 AM   #3
MidnightBlueGT's Avatar
Sure does. I tune for 93. Not that much more for better quality gas going into your car.
Old 10-27-2013, 01:55 PM   #4
dobypaw3's Avatar
Originally Posted by 1lowGT View Post
Yes
Read your owners manual. Ford recommends high octane in the coyotes. Most likely nothing will happen running 87 but if it does and the root cause was low 87 octane kiss your warrantee good bye. But, then it really does not matter seeing how the car is tuned. So the above would be for someone who does not have a tune and runs 87. FYI You are only saving about $5 on every fill up using 87. That is if you fill up at the 50 mile low fuel warning. Is the $5 savings really worth any future problems or a possible sluggish running motor?[COLOR="Silver"]
dobypaw3 is offline   Reply With Quote
Old 10-27-2013, 01:58 PM   #5
DallasStang77's Avatar
If you wanted to save money on gas with 87 octane you should have bought a Honda.
Old 10-27-2013, 01:59 PM   #6
dobypaw3's Avatar
Not to mention if anyone is worried about wasting the extra $5. Why in Gods name would anyone buy a GT. If wasting money on premium fuel is a concern then buy a V6.
Old 10-27-2013, 05:04 PM   #7
Region: Oregon
What manual are you reading? Ford recommends 87 Octane. Please don't give out inaccurate advice. It will not void your warranty.
Directly from the 2012 manual
Octane recommendations “Regular” unleaded gasoline with a pump (R+M)/2 octane rating of 87 is recommended. Some stations offer fuels posted as “Regular” with an octane rating below 87, particularly in high altitude areas. Fuels with octane levels below 87 are not recommended.
And directly from the 2014 manual
Regular unleaded gasoline with a pump (R+M)/2 octane rating of 87 is
octane levels below 87 are not recommended. Do not use fuels with
octane posted on pump below 87.
skramblr is offline   Reply With Quote
Old 10-27-2013, 05:22 PM   #8
dobypaw3's Avatar
I stand corrected. I would never give false info on purpose. I'm one who read all my vehicle owners manuals and I thought my GT manual said high octane. When in fact it was my motorcycles manual that stated minimum of 91.[COLOR="Silver"]
Old 10-27-2013, 06:02 PM   #9
2011's Avatar
The motor defiantly runs better with 93 octane on a stock tune. I do run 87 in winter and have had no problems.
2011 is offline   Reply With Quote
Old 10-27-2013, 08:11 PM   #10
FastFord13's Avatar
Your engines will advance timing when it detects higher octane fuel, it will make more power with a factory tune but tuning is where the true advantage of running higher octane lies. Putting higher octane like 93 is not a waste and does hold some benefits like making more power. Running 87 will not harm the engine.
Old 10-27-2013, 08:19 PM   #11
KARgt13's Avatar
You left out the next sentence which says running premium will improve performance. Yes regular is recommended, but premium gives better performance. It's an 8 hp increase between regular and premium.
KARgt13 is offline   Reply With Quote
Old 10-27-2013, 08:20 PM   #12
FastFord13's Avatar
Lol, you beat me too it. Lol. Correct sir!
Old 10-27-2013, 08:22 PM   #13
What manual are you reading? Ford recommends 87 Octane. Please don't give out inaccurate advice. It will not void your warranty. Directly from the 2012 manual Octane recommendations “Regular” unleaded gasoline with a pump (R+M)/2 octane rating of 87 is recommended. Some stations offer fuels posted as “Regular” with an octane rating below 87, particularly in high altitude areas. Fuels with octane levels below 87 are not recommended. And directly from the 2014 manual Regular unleaded gasoline with a pump (R+M)/2 octane rating of 87 is recommended. Some stations offer fuels posted as “Regular” with an octane rating below 87, particularly in high altitude areas. Fuels with octane levels below 87 are not recommended. Do not use fuels with octane posted on pump below 87.
The 5.0 makes more power with 93 compared to 87, without even a tune.
Old 10-27-2013, 08:22 PM   #14
he beat me to, I only use 89 or higher in mine.
Old 10-27-2013, 09:08 PM   #15
wstefek's Avatar
I run 89 octane and have no issues.
wstefek is offline   Reply With Quote
Old 10-27-2013, 09:12 PM   #16
JDM
JDM's Avatar
Ha Ha Ha!!!! Excellent point!!!
JDM is offline   Reply With Quote
Old 10-27-2013, 09:13 PM   #17
I've had issues running 87 in mine. Just seems to want to stall down low and doesn't seem to have any kind of get up and go & what feels like surging at times. Only worked well for a long drive back home constant 70-75mph. In my experience, I'd stick with 93 of you're doing anything but long distance highway driving.
laxmunkey26 is offline   Reply With Quote
Old 10-27-2013, 09:16 PM   #18
I stay away from 87, 89 or higher, no lower than 89
Old 10-27-2013, 09:23 PM   #19
Sorry yea that's what i meant. Stick to 91/93. Switching back and forth its a bad idea also.
Old 10-27-2013, 09:33 PM   #20
I've been doing 89 for 3 pill ups, 93 for 1, when gas is up in price, when it's low-ish for here, 93,93 etc
Old 10-27-2013, 09:38 PM   #21
I went from 93 to 87. Had all kinds the issues then.
Old 10-27-2013, 09:40 PM   #22
I don't think your ever supposed to go up it down more than 1 grade of gas at a time. So that's probably why
Old 10-27-2013, 09:42 PM   #23
Screaming Mach's Avatar
But aren't you?!
Screaming Mach is offline   Reply With Quote
Old 10-27-2013, 09:48 PM   #24
Originally Posted by Screaming Mach View Post
But aren't you?!
I don't know about that. Then again I've never seen another engine other than the coyote rated for the 87 and 93 octane. I would assume the ecm would adjust for the change in octane, but I'm not sure how long that takes.
Old 10-27-2013, 10:03 PM   #25
But aren't you?!
no, I'm not going MORE than 1 grade if gas, I'm going up or down 1 grade, from 89 to 93 and back, I wouldn't knowingly run 87 to 93, or 93 to 87
Old 10-27-2013, 10:08 PM   #26
Can you tell the difference between the grades of gas?
Old 10-27-2013, 10:10 PM   #27
not really, the engine does seem a little more live at 93 octane, other than that, and the HP max of 420, no.
Old 10-28-2013, 07:44 AM   #28
Am3gross's Avatar
So for roughly 5 bucks more every fill up you get 8 more hp... That's good bang for your buck right there!
2013 ford mustang gt, black, bought 16th of August. Only mod so far is tinted windows.
Am3gross is offline   Reply With Quote
Old 10-28-2013, 07:45 AM   #29
O ok
Old 10-28-2013, 08:27 AM   #30
2011's Avatar
Dead on. Nicely said..
Old 10-28-2013, 08:34 AM   #31
FastFord13's Avatar
You can run a tank of 87 down, fill up with 93/91, whatever is in your area. Your car will just advance or ****** timing depending on what grade you putting in.
Old 10-28-2013, 08:35 AM   #32
That I agree with, but what is in question is switching between 87 and 93 and vice versa from tank to tank of gas. Is that a bad idea?
Old 10-28-2013, 08:52 AM   #33
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Thanks.
Yes. A Mustang with a 87 Bama tune installed, will make more power than a Mustang with a factory tune and 93 Octane. You'll also notice more torque, acceleration, drive ability, gas mileage, throttle response, shift points (if auto) and much more over your stock tune!
I always run 93 octane in my car, even when I was stock. If you're looking for the most beneficial gains, I would recommend running a Bama 93 Race tune! This is going to be the most powerful and aggressive tune that we offer.
I hope this helps. If you have any further questions, feel free to shoot me a PM or you can give the Bama team a call and they'll gladly hook you up. You can reach them at the contact information in my signature!
-Dan
Old 10-28-2013, 09:09 AM   #34
Skulls98GT's Avatar
These guys mix different octane gas on purpose.
Code Red Shelby!!!
http://youtu.be/tDHX9GQwQcE
Skulls98GT is offline   Reply With Quote
Old 10-28-2013, 09:26 AM   #35
JDM
JDM's Avatar
+2
07:08 PM
