how much do I cut? - Mustang Evolution
Old 10-30-2013, 10:45 AM   #1
OzzyLiriano's Avatar
how much do I cut?
How much do I cut for a 1.5 drop?
OzzyLiriano is offline   Reply With Quote
Old 10-30-2013, 10:45 AM   #2
Old 10-30-2013, 11:50 AM   #3
1lowGT's Avatar
Try half coil
Old 10-30-2013, 12:18 PM   #4
bamf70's Avatar
Cutting springs can be dangerous, especially since aftermarket springs are a relatively low cost modification. If a modification is worth doing, it is worth doing correctly the first time.
bamf70 is offline   Reply With Quote
Old 10-30-2013, 12:31 PM   #5
No I was talking about the bump stop lmfao nvm I did it already
Old 10-30-2013, 12:33 PM   #6
bamf70's Avatar
Lol....I should have quoted the 1/2 a coil reply...
Old 10-30-2013, 12:46 PM   #7
1lowGT's Avatar
Ohhhhh lol
Old 10-30-2013, 03:45 PM   #8
I think you take the top nub off, thats what I had to do on mine
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 10-30-2013, 10:25 PM   #9
Evil2014GT's Avatar
You shouldn't have to cut at all. Im on steeda ultralites with close to 1.5" drop and i have plenty of clearance for the bump stops.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 10-30-2013, 10:34 PM   #10
Dude the k springs don't allow suspension travel. Your never gonna hit those bump stops.
Mikeyt03 is offline   Reply With Quote
09:58 PM
