Error code P2004 - Mustang Evolution
Old 11-02-2013, 09:19 PM   #1
Rjg12's Avatar
Error code P2004
Have a 2010 gt and I got a error code P2004 anyone know how to fix this has something to do with the throttle body
Rjg12 is offline   Reply With Quote
Old 11-02-2013, 10:37 PM   #2
Fader's Avatar
Region: Idaho
Have you done any mods lately? Intake, throttle bottle, manifold? Is your car running any differently?
Fader is offline   Reply With Quote
Old 11-03-2013, 01:37 AM   #3
xxPIKExx's Avatar
P2004 Intake Manifold Runner Control (IMRC) Stuck Open (Bank 1)
This DTC is set when the IMRC is commanded closed, but the IMRC monitor indicates open.
Possible Causes IMRC monitor signal circuit shorted to PWR GND or SIG RTN
Damaged IMRC actuator or solenoid
Blocked vacuum hoses
Diagnostic Aids Monitor the IMRC and IMRCM PIDs. The IMRCM state should change when the IMRC is commanded open or closed.
xxPIKExx is offline   Reply With Quote
Old 11-03-2013, 05:47 AM   #4
05Mystic's Avatar
Rig,
The imrc is a separate set of throttle valves that are between your intake and each head. They are controlled by an electric motor which is attached to the back of your intake. At lower loads they close and partially block your intake runners which increases air speed. When you throttle down, they open all the way up and let all the air go thru.
Sounds like they may be stuck open on one bank. There are little rods that connect to them and open and close them. I'm not sure if the rods can be seen with the intake is on. My intake is currently off. If some pics would help, let me know.
05Mystic is offline   Reply With Quote
Old 11-03-2013, 10:06 AM   #5
Rjg12's Avatar
Thanks everyone for the advice I have put the car away for the winter so maybe I will take it apart and clean it up and see if that helps
---------- Post added at 11:06 AM ---------- Previous post was at 11:04 AM ----------
Hi fader yes I did I put in a airaid intake but that was about 2 months ago just got the code the other day
03:28 AM
