Slight steering vibration - Mustang Evolution
Old 11-03-2013, 08:43 PM   #1
Okay so I have noticed a vibration in my steering as of a few days ago. I installed a set of staggered 20" AMRs that had been mounted/balanced by AM. The vibration is most noticeable around 40-45mph and then comes back at 65-80. Do I need to get these tires rebalanced locally? I know it wasn't doing this before on stock wheels and I am not sure if its just something that comes with a smaller sidewall and 20" wheels. I've never had 20s before
Old 11-03-2013, 08:59 PM   #2
Mustang 4pt0's Avatar
Has it been lowered? You ought to get it aligned. Especially if you've lowered it.
Mustang 4pt0 is offline   Reply With Quote
Old 11-03-2013, 09:14 PM   #3
smbeard's Avatar
My staggered set fron AM was overinflated and had to be rebalanced. It's a likely culprit, and it's easy to get checked out.
2013 Grabber Blue GT Premium, JLT CAI, BMR Rear LCAs, Kooks LT Headers (1 7/8 x 3"), Kooks High Flow Catted X-Pipe, MBRP Pro Series Catback, AMR Charcoal Drifts Staggered.
Thanks to Jason at www.hypermotiveperformance.com for the great deals!
smbeard is offline   Reply With Quote
Old 11-03-2013, 10:56 PM   #4
It has the ford racing suspension kit, and I had it aligned about 8 or 9 months ago. Haven't touched anything on the suspension since then. I'm thinking its probably wheel balance, or I hope so
Old 11-04-2013, 05:10 AM   #5
Grabber Blue5.0's Avatar
Either wheel balance or a problem with the EPAS which is rare but can happen. You could put your stock tires/wheels on and see how it reacts that way. That would tell you if you have a wheel balance problem.
Old 11-04-2013, 10:35 AM   #6
I sold them to recoop money lol! I know for certain they don't do it with the stock wheels. I think ill go to a discount tire an see if they will help me out.
Old 11-04-2013, 12:13 PM   #7
tc x 4's Avatar
Have it documented so you can get the money refunded by AM. Hopefully it's just a balance problem and not a defective wheel. Oh, I almost for got, there is retainer washers on the rotors from factory that have to be removed. The factory wheels are recessed to allow for them, most aftermarket wheels are not.
---------- Post added at 02:13 PM ---------- Previous post was at 02:10 PM ----------
The retainer will be on one of the studs.
Old 11-04-2013, 02:46 PM   #8
Evil2014GT's Avatar
This. Make sure that retainer is removed, or it will definitely cause a vibration. I had a slight vibration when i first got my wheels as well, then i did some research and found out about the retainers. Took the wheels off, removed the retainers, and i was good to go.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 11-04-2013, 02:50 PM   #9
HPFury's Avatar
Larger stock wheels are better than after market. For a mustang the wheels should be certified to at least go up to 120 MPH. If they can't guarantee that then stick to stock. Best of luck.
HPFury is offline   Reply With Quote
Old 11-04-2013, 03:05 PM   #10
I definitely saw those and didn't remove them! I will try this!
---------- Post added at 05:05 PM ---------- Previous post was at 05:04 PM ----------
I like hearing this. I will check it out
Old 11-04-2013, 03:09 PM   #11
Evil2014GT's Avatar
I bet that's your problem. If you notice on the back side of the stock rims, there is an indentation for that retainer to fit into. On the aftermarket rims, its just a flat surface. So the rim technically isnt laying flush.
Old 11-05-2013, 01:27 PM   #12
TorchRed6's Avatar
if that doesnt solve your problem, make sure you got tires and rims that are actually round. i finally got mine under control after AM sent me about 3 new tires and a couple rims. its not completely fixed yet.my front right rim i believe it still out of round but its not very noticable now. they were great about sending out replacements and repaid me for around $230 in mount and balancing bills.
TorchRed6 is offline   Reply With Quote
10:45 AM
