Clutch issue? Please advise. - Mustang Evolution
Old 11-07-2013, 06:47 AM   #1
SystemCritical's Avatar
So I noticed something yesterday that's got me worried. I was driving along and a GTO pulled up next to me. We were running 30/35. I dropped her into 2nd and jumped on her for about a block. This is when I noticed my clutch pedal would not come all the way back up. It was stuck half way down. I pulled into a parking lot, side stepped it a few times and it popped back up. No issue since but I haven't ran her hard again. I'm freaked out about it. I am going to the strip on the 22nd but now I'm worried to run her hard.
Thoughts?
---------- Post added at 07:47 AM ---------- Previous post was at 07:46 AM ----------
Oh, stock clutch and MT82 trans.
SystemCritical is offline   Reply With Quote
Old 11-07-2013, 06:51 AM   #2
Screaming Mach's Avatar
There's a vid of that problem on YouTube
Screaming Mach is offline   Reply With Quote
Old 11-07-2013, 07:03 AM   #3
Would happen to have the link or what key words would work would you?
Old 11-07-2013, 07:06 AM   #4
DWC_SmOziLLa's Avatar
Do not fix it half way by removing the clutch assist spring. Such a stupid and half a$$ed way to do it. Replace your stock hydraulic clutch line, very easy to do and many choices are out there. The factory clutch does not like high rpm shifts due to the small diameter and high expansion of the factory hydraulic line. Replace it, top off your fluid, pump your clutch 100 times because it's a self bleeding system, recheck fluid, and enjoy. The best $60-$80 you'll ever spend on your car. Good luck!
Old 11-07-2013, 07:09 AM   #5
Thanks man. Glad to hear it's an easy fix. Will order today.
Old 11-07-2013, 07:16 AM   #6
No problem. This is what I have and it works great! Never has happened again.
http://www.americanmuscle.com/mcleod...ne-0513v8.html
Old 11-07-2013, 07:18 AM   #7
No problem. This is what I have and it works great! Never has happened again. http://www.americanmuscle.com/mcleod...ne-0513v8.html
That's the one I want but is shows out of stock. Need to find one ASAP.
Old 11-07-2013, 07:21 AM   #8
Try this. It'll work fine.
http://www.americanmuscle.com/sr-hyd...ne-0514v8.html
---------- Post added at 09:21 AM ---------- Previous post was at 09:20 AM ----------
Or this
http://www.jpcracing.com/jpc-2005-20...-line-upgrade/
Old 11-07-2013, 07:42 AM   #9
Someone just informed me there is a tab out for it.
Old 11-07-2013, 07:51 AM   #10
Good luck with that. Lol. You couldn't pay me enough to take my car to a dealer for service. I'd rather sell it.
Old 11-07-2013, 09:46 AM   #11
Strange Mud's Avatar
if you replace your clutch line....DO NOT DROP THE RETAINING CLIP!!!!!!
also you may have to re-bleed it the next day with 100 more pedal pumps.
oh yeah, do NOT drop the clip.
long needle nose are the trick to get the clip out plus it's an excuse to go to Home Depot/Lowes and get a set!
Old 11-07-2013, 09:48 AM   #12
Originally Posted by Strange Mud View Post
if you replace your clutch line....DO NOT DROP THE RETAINING CLIP!!!!!! also you may have to re-bleed it the next day with 100 more pedal pumps. oh yeah, do NOT drop the clip.
Lol, I have read that in many DIY posts. Duly noted.
09:58 PM
