Side scoop removal - Mustang Evolution
Old 11-16-2013, 08:57 AM   #1
Side scoop removal
Anyone know what holds the side scoops on a 14 GT?
Bought mine off the lot with them, would like to remove them but don't know if there are fasteners or just tape holding them on.
014SterlingGT is offline   Reply With Quote
Old 11-16-2013, 10:13 AM   #2
TorchRed6's Avatar
every side scoop i've ever seen was held on by 3m tape.
TorchRed6 is offline   Reply With Quote
Old 11-16-2013, 11:58 AM   #3
Getn off's Avatar
Yes, 3m tape. Best to use fishing line and a plastic putty knife for removal. Do it in the sun, or use a heat gun/hairdryer.
Troy
Getn off is offline   Reply With Quote
Old 11-20-2013, 07:07 PM   #4
Alkhalil's Avatar
You might also want to squirt some alcohol to weaken the bond, but careful not to combine with a heat gun.
Alkhalil is offline   Reply With Quote
Old 11-20-2013, 11:38 PM   #5
11stangGT's Avatar
Region: Arkansas
Why? Lol the best thing to use is your fingers and a heat gun. I work at an accessory shop and have do this several times a week. Might get some blisters from rubbing if you don't switch between fingers lol. No chance of scratching it then and it really is the easiest and fastest way I have found..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 11-20-2013, 11:41 PM   #6
2 Stangz's Avatar
Region: Nevada
+1 sounds ab right.
OP if you're not comfortable doing this yourself, take it to a reputable tint/auto decal shop. They'll have them off in under 15 mins.
I believe some of the New Edges that came with OEM side scoops actually had nasty "holes" in the 1/4 panels under the scoops.
Old 11-22-2013, 01:50 AM   #7
elkk's Avatar
Very simple, nylon fishing line or dental floss. No need for a heat gun. In fact I wouldn't even consider it. Heat might warp the side scoop or damage the paint. It'll take you less than 5 minutes a side, I'd like to have the original ones, shoot me a private message.
2014 GT / Ruby Red / MT82 / 3.73 / RR Sensing & Security
Mods: GT500 Axlebacks, Modest Pin Stripe, Side Scoops, Wheel Spinners, Lower Fog Lights, Strut Tower Brace, Chrome Shift Knob
elkk is offline   Reply With Quote
10:00 AM
