Raxiom Smoked Headlights problem - Mustang Evolution
Old 11-20-2013, 05:51 PM   #1
JonathanMustang's Avatar
Hello all,
I had to turn on my bright lights because the halos aren't that bright.
The problem is that only the right light on my passenger side is working. Can it be an issue with the wiring on the driver side?
JonathanMustang is offline   Reply With Quote
Old 11-20-2013, 05:55 PM   #2
Originally Posted by JonathanMustang View Post
Hello all,
What?
I have the same headlights. Two questions
1. Are you talking about the headlight itself or the halo?
2. Factory HIDs, no HIDs or aftermarket?
Old 11-20-2013, 06:04 PM   #3
Originally Posted by ZLwhat View Post
What? I have the same headlights. Two questions 1. Are you talking about the headlight itself or the halo? 2. Factory HIDs, no HIDs or aftermarket?
Sorry. I'm talking about the headlight itself. Only the turn signal light works.
Old 11-20-2013, 08:16 PM   #4
Old 11-20-2013, 09:49 PM   #5
Well if you have aftermarket HIDs I would suggest checking the ballast on that side. If your headlights are the normal halogens, I would suggest that you make sure it's actually plugged in in the back. It's also possible that you blew the fuse in your fuse box if you have factory HIDs. I don't remember the fuse number but it's under the hood if you did.
Old 11-20-2013, 09:51 PM   #6
It's the bulb that went out. I don't have HIDs. I cannot find a H9 bulb. Am I able to use a silver star H11 bulb?
Old 11-20-2013, 09:52 PM   #7
Old 11-20-2013, 11:51 PM   #8
No you can not. You should have an extra set of bulbs from the swap. I'd recommend upgrading to HIDs at this time or you can find h9 at a local auto parts store. Raxiom had a nice set of h9s made for these headlights if you're interested as well
Old 11-20-2013, 11:58 PM   #9
2 Stangz's Avatar
Region: Nevada
If you go HID's:
Intense White H9 6000k HID Light Conversion Kit
Old 11-21-2013, 08:36 AM   #10
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
It sounds like the bulb just went bad. You can throw in a replacement bulb and I'd bet you're good to go! Or you could take this time to upgrade to a set of HID's. Either way, this is a simple fix ! Let us know if you have any questions or need some assistance. We can definitely help you out with a replacement bulb on us, if it was the Raxiom bulb that went bad!
Just shoot me a PM and let me know what I can do for you!
-Dan
Old 11-21-2013, 09:14 PM   #11
Originally Posted by 2 Stangz View Post
Thank you! What ballast series do I check?
* BALLAST SERIES:
Signature Series (35w)
Power Series (55w)
Stealth Series (Slim)
Volt Canbus Series (Premium)
Old 11-22-2013, 01:32 PM   #12
2 Stangz's Avatar
Region: Nevada
I recommend the stealth series!
I linked you to a set of 6000K or what I describe 6000K as "diamond white." It's white with a tiny hint of blue (cyan) in it. From my own testing, 6000K matches today's CCFL halo lighting the best. If you want a pure white (OEM-looking), go with 5000K. Honestly, you can't go wrong with either. Just some extra info, take it or leave it.
Old 11-22-2013, 01:41 PM   #13
Thank you very much!! I'll go with the 6000K. Dumb question, but is the $69 HID Stealth Series for both lights or is it $69 each light? lol
Old 11-22-2013, 01:46 PM   #14
2 Stangz's Avatar
Region: Nevada
The $69.99 price tag is for the entire kit, i.e. 2x 6000K H9 bulbs, 2x Stealth Series ballasts, 1x wiring harness, and a 1yr warranty with free shipping. Shipping usually takes 2-3 days.
Old 11-22-2013, 01:56 PM   #15
Thumbs up
Just purchased them! Thanks again for your help.
Old 11-22-2013, 02:00 PM   #16
2 Stangz's Avatar
Region: Nevada
No problem.
Old 11-24-2013, 06:42 PM   #17
Now I have water vapor inside my headlights. Any suggestions?
Old 11-24-2013, 07:27 PM   #18
You needed to seal the seams with silicone. Am will replace them if u send them pics. I sealed mine and they still let moisture in : / ended up selling that car before I could contact AM about it.
Mikeyt03 is offline   Reply With Quote
Old 11-24-2013, 11:59 PM   #19
2 Stangz's Avatar
Region: Nevada
My smoked turn signals I bought from AM got moisture in them after a hurricane had just rolled in (had just installed them too). Turns out the instructions said it could actually happen and was normal. It took a few days but the moisture disappeared and never came back.
Old 11-25-2013, 10:04 PM   #20
Benzopyrene's Avatar
Just got mine installed a few weeks ago, noticed the drivers side had a ton of condensation. Also noticed some free water along the seals at the bottom. Took em off, dumped al the water out that I could then I cracked the seal they had in place to get some extra out. Let it air dry by the window unit I have in my garage for about 4 hrs. All water appeared to be gone, so I resealed it, including where the rubber gaskets in the back were. Its been a lot better, still get a really tiny amount of condensation, but its much better. The problem I was having was the halo on that side was actually dimmer, but now its back to normal. Dont know what happened, but glad I fixed it. I do think its silly that I had to seal brand new headlights. Just wish I had seen that in the instructions somewhere. I emailed AM abut it before I did any of this, but never heard back from them, so just went ahead and tried to fix it myself. Warranty is probably no good anyway since I installed HID's. Hopefully they will continue to work.
Benzopyrene is offline   Reply With Quote
Old 11-25-2013, 10:09 PM   #21
2 Stangz's Avatar
Region: Nevada
^The wires that come out of the halo converter box and go to the CCFL bulbs themselves are REALLY sensitive. I found that shortening the wires actually made the light output brighter.
Old 11-25-2013, 11:33 PM   #22
I just got my HID kit. Installing the HID bulbs right now. How do I close the cap behind the light bulbs. The HID kit wires seem to be in the way for it to close.
Old 11-26-2013, 02:04 PM   #23
Cut a hole in it. Here is mine
Old 11-26-2013, 02:07 PM   #24
That's what I did. Now when I turn in my car I get this alert lol
Old 11-26-2013, 02:57 PM   #25
Well lol, how did you wire the HIDs? I have to ask.
Old 11-26-2013, 03:13 PM   #26
Lol I followed the instructions on this website:
It was pretty much plug and play. I did the single beam installation.
---------- Post added at 04:13 PM ---------- Previous post was at 04:12 PM ----------
It's weird because my alarm still works.
Old 11-26-2013, 03:15 PM   #27
Did you get bi-xenon or single bulb?
Old 11-26-2013, 03:18 PM   #28
I got the xenon bulbs.
Old 11-26-2013, 03:19 PM   #29
Okay, you are probably having issues with the ground wires. Where did you ground them?
If its not the ground wires, did you run the power wire straight to the battery or where did you run it?
Old 11-26-2013, 03:26 PM   #30
Hmm it didn't have anything to groud the wires. It was all plug and play.
Old 11-26-2013, 03:39 PM   #31
Well if it didn't have anything to ground the wites then you didn't get bi-xenon. The only way you're going to get a code like the one you got is by messing with the factory wiring in the radio, PATS system or drawing too much charge through your electrical system by grounding out wires.. Etc. do the headlights work Atleast?
Old 11-26-2013, 03:54 PM   #32
I see. I'm new to the whole HID stuff. lol
These are the bulbs I received. Click image for larger version
Old 11-26-2013, 04:11 PM   #33
So basically it was just a couple clips and that's it? If that is true then you just got a non-relay kit. I'd say that you are probably pulling too much voltage across one of those ballast
Old 11-26-2013, 09:34 PM   #34
2 Stangz's Avatar
Region: Nevada
H9 bulbs are single-beams (essentially low-beams) and are not bixenon (essentially low and high-beams). His kit most likely only came with bulbs and ballast, and not a relay harness that connects to the battery and chassis of the car.
@ZLwhat, from my understanding, halogen bulbs draw 55w each and the HID kit he ordered only draws 35w each.
@OP, are you sure you didn't loosen a connection vital to your factory security system when installing your HID's? If not, then there are three solutions you can try:
1) Simply unplug the HID ballasts, plug your halogen bulbs back in (you don't have to put them back in the headlight assembly), and see if you get that error still. If the error goes away, then it's the HID's. Proceed to the next two options:
2) Order and install these - Universal HID Capacitor (Pair) - HIDeXtra.com, if these don't work, send them back and HID Extra will completely refund you.
3) Order and install this - Universal HID Relay Harness - HIDeXtra.com, once again if this doesn't work, you can send it back for a full refund.
Old 11-30-2013, 11:30 AM   #35
Thanks! They are going to send me a capacitor for free!
11:10 AM
