Coilover kits - Mustang Evolution
Old 11-23-2013, 08:21 PM   #1
huhalbert's Avatar
Coilover kits
I've been looking into getting coil overs for my 13' 5.0. Anyone have any suggestions on which ones to get? I'm currently on eibach pro-kit springs with stock shocks and struts. The ride is pretty uncomfortable, so I'm debating between getting H&R supersport springs with the eibach shock and strut kit, or just getting coilovers. Im looking to drop my car maybe 2 inches at most in the front and 2.5 at most in the rear. The h&r's look like they drop it the perfect amount. Any suggestions?
huhalbert is offline   Reply With Quote
Old 11-23-2013, 10:26 PM   #2
08mustanggt's Avatar
Sorry, no suggestions, just had to say that you have a GORGEOUS car and its easily the nicest 5.0 I've ever seen. Only car I'd even consider selling my turboed s197 for.
08mustanggt is offline   Reply With Quote
Old 11-24-2013, 12:07 AM   #3
KW Suspension V3 Mustang Coilover Kit 35230045 (05-14 GT, V6) - Free Shipping 35230045
Old 11-24-2013, 12:22 AM   #4
MidnightBlueGT's Avatar
I agree. You got a beauty. Makes me excited for next year when I try to get a 14 5.0 or thats the plan.
Old 11-24-2013, 04:02 AM   #5
audioAl's Avatar
That is one great looking GT!
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 11-24-2013, 06:33 AM   #6
jayman33's Avatar
Ground Control coilovers, KW is great as well. I'm running Ground control but I'm switching out to AST.. just waiting for them to get here. Ground control you get the best for the money (CC plates/ Custom spec dampening/ adjustable and koni lifetime warranty)
A boss.....
jayman33 is offline   Reply With Quote
Old 11-24-2013, 12:47 PM   #7
But which one has the best ride? Lowering springs suck lol
Old 11-24-2013, 01:01 PM   #8
Well if they have adjustable shocks/struts you an change the feel of the ride.
Old 11-24-2013, 01:18 PM   #9
Yeah I know that. But some of them offer adjustability in many different shapes and forms. Spring rates differ from make to make and dampening can only be increased/decreased so much. That's why I am asking what his experience was as far as ride quality.
Old 11-24-2013, 01:40 PM   #10
jayman33's Avatar
Best ride is subjective, what I think is comfortable may seem unbearable to someone else. I really liked the ground control setup, you can get a specific dampening setup and spring rate which is something I like about GC.
A boss.....
Old 11-24-2013, 01:46 PM   #11
Right.
I was asking for your opinion specifically, but I didn't necessarily word it that way. I'm currently looking into coil overs because I can't find a drop spring set-up that's ride comfortably and still gives a little drop.
Old 11-24-2013, 01:51 PM   #12
It's not me, it's you.
primer2tone's Avatar
I've got BC coilovers. The ride is much better then lowering springs but it's still a pretty stiff ride. But then again, I like it pretty low. I imagine the ride quality would be better if it was higher and I reduced the preload on the springs.
Old 11-24-2013, 01:54 PM   #13
jayman33's Avatar
Attachment 138054
Very true, I noticed a huge difference after I raised the car up .75", the handling was actually better as well allowing for increased dampening ability and travel.
A boss.....
Old 11-24-2013, 09:19 PM   #14
Oh2freshstang's Avatar
How do coil overs work..are they like normal shocks/struts that they eventually have to be replaced? Sorry OP don't mean to thread jack just didn't wanna create a new thread.
Old 11-25-2013, 06:51 AM   #15
Coilovers do the exact same job as the strut & spring. They wear out just the same. The difference is, coilovers are hight adjustable and spring rate adjustable.
Old 11-25-2013, 09:12 AM   #16
Ah ok. Makes sense thanks!
Old 12-03-2013, 11:38 AM   #17
Lawrence's Avatar
KW V3's are expensive but worth it. High quality product. You know you'll need various other suspension components to do that kind of drop, right? just making sure.
Lawrence is offline   Reply With Quote
Old 12-03-2013, 02:48 PM   #18
jayman33's Avatar
I would go with AST over KW, they're close to the same price and you'll get more out of the monotube AST's.
A boss.....
Old 12-03-2013, 04:28 PM   #19
Is KW sister company ST coilovers any good?? What about megan racing?
Old 12-03-2013, 05:28 PM   #20
jayman33's Avatar
KW builds ST suspensions. Their CO kit is basically the KW V1 kit without the stainless bodies.
A boss.....
Old 12-03-2013, 05:58 PM   #21
Ah ok.
Old 12-28-2013, 08:30 PM   #22
MythlinMasterdo's Avatar
What about Eibach coilovers?
MythlinMasterdo is offline   Reply With Quote
Old 12-29-2013, 01:20 AM   #23
You may find that merely investing in some quality shocks with your current setup may suit your needs. The factory shocks weren't designed to operate at that height and spring rate. I had the same setup (Eibach springs, oem shocks), went with a Ford Racing matched setup, and couldn't be happier...rides a little bit higher, so my ground clearance was improved. I didn't want to flatten my longtubes...
Grey 2011 GT Brembo, 3.73, ARH LT headers, catted x-pipe, Borla GT500 A/B, JLT cf CAI, MGW shifter, SCT, tuned, Boss oil cooler, Ford Racing springs & adj shocks, GT500 strut mounts, Steeda adj panhard/upper & lower arms. Roush 18x10" wheels with PS2 fronts, R888 305's rear. Eibach GT500 adj swaybars, Boss IM/Strut bar/steering wheel, Ford Racing 90mm TB, GT500 wing, BMR relo brackets, DSS aluminum driveshaft, Cervini Cobra R hood, 2014 GT500 headlight & rear end retrofit...
Matt K is offline   Reply With Quote
Old 12-29-2013, 03:07 PM   #24
I really want to get a 2-2.5" drop in my car though, I also don't want a super stuff ride which I know coilovers are adjustable. I also only have about $1600 to spend.
Old 01-05-2014, 03:45 PM   #25
kramer's Avatar
Region: New Hampshire
off the subject but where did you get the stripes? are they factory?
---------- Post added at 05:45 PM ---------- Previous post was at 05:43 PM ----------
Was the ford racing adustable or not? I'm about to spring for them (pun intended) but on the fence.
kramer is offline   Reply With Quote
Old 01-05-2014, 04:38 PM   #26
NewMtang's Avatar
Thumbs up
I may be wrong but as I understand your post, you are trying to do the opposite at the same time.
A stiffer suspension and lowering means you will be beat to death by the smallest bumps in the road. A trip on country roads mean you will be black and blue after getting home. Also when dropping your car, you will have less clearance for your wheel wells.
If you don't lower it, you can get a suspension that rides smooth. Like the stock suspension that came with your car.
Old 01-06-2014, 01:06 PM   #27
kramer's Avatar
yes, you are wrong. I am changing the suspension to improve handling (as i mentioned I do race the car on the road courses.) Lowering the CG is part of it. If the suspension change beats the crap out of me then it's a BAD suspension and that is not what I will be installing. Further, the suspension will be adjustable so I will have the option to adjust per my needs. My concern was bottoming out at the lower heights and my concerns have been addressed by others within and outside of this forum.
Old 01-07-2014, 10:35 AM   #28
Bodyman's Avatar
So what do people think about the Eibach shocks and struts.
Bodyman is offline   Reply With Quote
Old 01-07-2014, 02:20 PM   #29
jayman33's Avatar
Eibach shocks and struts are pretty bad, one of the only brands that design and make struts that cant support their own springs. We've sold tons of Koni STR.T with great success and now they offer the orange for the 11+ Cars.
A boss.....
Old 01-07-2014, 02:32 PM   #30
KW and Griggs Racing have some pretty badass coilovers.
Old 01-07-2014, 03:22 PM   #31
Bodyman's Avatar
Ya my wife ordered me some Eibach for Christmas. I wanted the koni but my wife talked to AM. Helped here. Called to try to send them back so I could swap them for koni's but they didn't really want to help with that.
Old 01-07-2014, 04:28 PM   #32
kramer's Avatar
I'd call em again...ask to talk to the next guy up the chain...they are usually really good with service
Old 01-07-2014, 05:18 PM   #33
Bodyman's Avatar
Coilover kits
I've bought a few thing from them. Really haven't had to deal with customer service. But I've heard a lot of good things about them. But I guess I'll find out.
« TPS | Kooks/pypes »
10:03 AM
