Installed Lethal Off Road X Pipe with GT500 Quad Tip Mufflers - Mustang Evolution
Old 11-27-2013, 01:40 PM   #1
Deerslayer's Avatar
Finally finished the exhaust. 3" from front to back. Lethal Off Road X, 3" Pipes w/SVT - GT500 Quad Tip Mufflers. Installed the TruCarbon quad tip diffuser too
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 11-27-2013, 01:46 PM   #2
Getn off's Avatar
Very nice! Was really leaning this way for looks, but decided against and go strictly for sound...Atak.
Troy
Getn off is offline   Reply With Quote
Old 11-27-2013, 01:54 PM   #3
Deerslayer's Avatar
He has to cruise through a golf course every day that the members get the red *** about how loud his car was. He has had multiple complaints so this is an awesome setup. Nice low sound cruising but when you romp it she roars.
Old 11-27-2013, 02:10 PM   #4
Sounds good. Seems like some rasp do you still have resonators?
JayblesStang is offline   Reply With Quote
Old 11-27-2013, 03:12 PM   #5
Deerslayer's Avatar
No resonators. 3" pipe from x pipe to gt500s
Old 11-29-2013, 12:50 PM   #6
awesome sound!!!
JWButler14 is offline   Reply With Quote
Old 11-29-2013, 04:27 PM   #7
I'm after the perfect exhaust setup.
Your car sounds better than any I've heard to date. I just ordered the GT500 Quad tip exhaust with the diffuser ( The carbon one looks SICK on your grey car)
I want to know, Which Lethal pipe do you have? There are quite a few on there site. I want to order the same one. What kind of tune do you have? Do you have check engine lights without cats?
Justin81 is offline   Reply With Quote
Old 11-29-2013, 05:02 PM   #8
Deerslayer's Avatar
It sounds way better than the clip too. It turns heads everywhere.
Here is the Lethal Off Road X pipe. Ours is the 3" stainless, but the one that is $100 cheaper is the same.
Lethal Performance 2011-2014 5.0L Mustang 3" Offroad X-pipe (T304 Stainless Steel) - Lethal Performance - Mid-Pipes - Exhaust - 2011-2014 Mustang GT 5.0L
We bought the 3 tunes from MPT. http://www.morepowertuning.com/mustang
UNBELIEVABLE difference in this tune and the last we had. He is running a 93 octane performance tune that is aggressive. We have a 91 tune that is a little less aggressive and an 87 tune that is for long trips and mileage. Cant say enough how happy we are with MPT and the tunes. No check engine lights at all, the car idles perfect and it is a beast both off the line and WOT from any roll. The video is from 65mph roll and it will flat out scream. Need better tires that will hook better though. It gets squirley when you shift to 3rd and looses a ton of traction.
Old 11-30-2013, 11:28 AM   #9
JonathanMustang's Avatar
Wow sweet
JonathanMustang is offline   Reply With Quote
Old 12-04-2013, 08:57 AM   #10
When you did the rear GT500 valance, did it come with any instructions or hardware? Mine is just a plastic valance thrown in a box with nothing.
Old 12-04-2013, 09:25 AM   #11
Deerslayer's Avatar
You use the hardware from your old valance. Removing the license plate lights can be a pain in the ***. Removing the bumper is easy as it just pretty much snaps off. We had to trim a bit more of the bumper to fit the carbon fiber valance we had. Overall the install is pretty easy if you have the right tools to cut. I have air tools with die grinders and cut off wheels, so it went pretty quick. Just cut off following the line and then fit on the valance and re-trim and re-fit if necessary.
Old 12-04-2013, 09:33 AM   #12
Thanks!
So it doesn't require any new hardware at all? Just the factory stuff? I forgot yours was the carbon Fiber one.
I'm either going to install mine at my buddy's body shop or just drop it off at a different body shop that I know of. Depends on what kind of time I can make.
Old 12-04-2013, 11:33 AM   #13
Deerslayer's Avatar
No, you wont need any additional hardware.
01:26 PM
