Coyote exhaust camshaft upgrade?? - Mustang Evolution
Old 11-30-2013, 07:33 AM   #1
I ran across this part again and was wondering has anyone had any experience with this product:
Ford Racing M-6550-M50GTE
M-6550-M50GTE Mustang Ford Racing Exhaust Camshaft Set GT 2011-2014 | CJ Pony Parts
This camshaft was made specifically for us stock Coyote head owners, all so you don't have to machine a portion of the seat below the rocker arm.
My question for anybody that has used this FRPP camshaft upgrade, will this slightly longer duration give a benefit in the higher RPM range. If so how does that work out considering that the engine is still running the stock Coyote intake manifold?
Also I do understand that this camshaft set needs the boss 302 valve springs or better.
draxxus131 is offline   Reply With Quote
Old 12-03-2013, 11:33 PM   #2
Compstall's Avatar
There's a set on Craigslist locally thats been for sale a long time. Guy is down to $300 last I looked.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 12-04-2013, 09:19 AM   #3
Compstall's Avatar
Just found the ad again, he's down to $200.
- Brent
Old 12-04-2013, 11:47 AM   #4
Deerslayer's Avatar
Probably had a tough go getting someone to tune it right with those cams.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 12-04-2013, 12:01 PM   #5
Compstall's Avatar
Correction, the cams in the ad are stock Boss exhaust cams, guy put Comp Cams in his car.
- Brent
Old 12-04-2013, 12:37 PM   #6
I don't know anyone who would spend the money to do this upgrade. There are easy and less expensive ways to bolt on big power and keep the heads bone stock.
exhaust
04:05 AM
