2013 raxiom smoked halo headlights - Mustang Evolution
Old 11-30-2013, 07:24 PM   #1
huhalbert's Avatar
I'm currently debating whether i should buy the Raxiom smoked halo headlights for my 2013 5.0. I currently have the halo foglights, but the color of the halos of the foglights and the factory headlights are different colors. The fogs are slightly blue while the headlights are a bit yellow. Anybody have any suggestions or pictures of their halo headlights on a 2013? Or even better, halo headlights and halo foglights on the 2013.
huhalbert is offline   Reply With Quote
Old 11-30-2013, 07:59 PM   #2
Not at 2013 but it's a 2012 and headlights can change over between models
ID:	139095   Click image for larger version
Old 11-30-2013, 08:02 PM   #3
2 Stangz's Avatar
Region: Nevada
Hopefully you did NOT take your new black car through an automatic car wash...
Old 11-30-2013, 09:01 PM   #4
Stang8psi's Avatar
Region: Delaware
Looks like a no touch??
Stang8psi is offline   Reply With Quote
Old 11-30-2013, 10:29 PM   #5
huhalbert's Avatar
It was a professional handwash! They take good care of my car don't worry
Old 12-01-2013, 06:37 AM   #6
Oh2freshstang's Avatar
2012 & 2013 use the same headlights? They're interchangeable?
Old 12-01-2013, 02:04 PM   #7
2 Stangz's Avatar
Region: Nevada
PHEW! I was really worried ab that beauty of yours taking an undeserved beating
Yes. I haven't tried it but I'm almost completely positive if I wanted to I could order 2013 headlights and put them on my 2010 with factory HID's.
Old 12-01-2013, 04:07 PM   #8
PHEW! I was really worried ab that beauty of yours taking an undeserved beating Yes. I haven't tried it but I'm almost completely positive if I wanted to I could order 2013 headlights and put them on my 2010 with factory HID's.
Interesting! So is there a way to put the 2013 OEM HID headlights on a 2012 non hid headlights? Are they interchangeable of does the non-hid make a difference?
Old 12-01-2013, 05:03 PM   #9
Yes they are completely interchangeable and there is a wiring harness available online that makes them plug and play for non-hid cars. You will need the headlights, ballast, and bulbs in conjunction with that harness.
---------- Post added at 06:03 PM ---------- Previous post was at 06:02 PM ----------
If you have factory HIDs, it is a direct swap.
Old 12-01-2013, 05:08 PM   #10
Yes they are completely interchangeable and there is a wiring harness available online that makes them plug and play for non-hid cars. You will need the headlights, ballast, and bulbs in conjunction with that harness. ---------- Post added at 06:03 PM ---------- Previous post was at 06:02 PM ---------- If you have factory HIDs, it is a direct swap.
That's awesome thanks! Now I gotta find me some! Would u happen to know a link where I can find everything I need to make it work on my non-hid car?
Old 12-01-2013, 05:15 PM   #11
I'll have to look up the harnesses website but they have everything on eBay. Even the headlights which are cheaper on eBay than anywhere else I have seen them. A guy on SVTP is selling a entire plug and play set-up for 1k. You can get by cheaper though.
Old 12-01-2013, 05:23 PM   #12
Yea I was actually just looking at the one on SVTP. Ima look on eBay because for 1k id rather just got with raxiom's projector lights! I just want something a lot brighter than oem!
Old 12-01-2013, 05:27 PM   #13
Well I have the raxioms and they need headlights to be bright at all. Honestly a retrofit that is custom done is way cheaper and far better than oem lights. But if you want oem you will pay more money $$$.
I run a relay 35watt morimoto set up in my 2012 with raxiom headlights. It's plenty bright for me and the cut off is great for aftermarket headlights.
Old 12-01-2013, 05:45 PM   #14
Well I have the raxioms and they need headlights to be bright at all. Honestly a retrofit that is custom done is way cheaper and far better than oem lights. But if you want oem you will pay more money $$$. I run a relay 35watt morimoto set up in my 2012 with raxiom headlights. It's plenty bright for me and the cut off is great for aftermarket headlights.
The only thing I don't like about the raxiom is the halos's but I can live with them if there that much cheaper than going oem hids! So if I get the raxiom's all I would need to make them brighter is replace the bulbs??
Old 12-01-2013, 05:57 PM   #15
If you already have HIDs, then yes. If you don't have HIDs you will need a H9 hid kit that's is aftermarket. And if you don't like the halos just contact sickhids or something similar and get a retrofit. You can get a legit retrofit done that is similar to headlights of Acura, BMW, Mercedes cars for around $400 and it will be better and brighter than you ever imagined. I like my halo set up, and the headlights are great with HIDs
Old 12-01-2013, 07:00 PM   #16
Yea the halo's are kind of growing on me! I'm gonna look up the retrofit one & see what's the best option I can get for my $! Thanks for all ur help bro! Sorry OP for thread jacking.
Old 12-02-2013, 02:53 AM   #17
Question. I have aftermarket hids on the stock fogs. Will I need to change anything if I switch to the raxiom fogs?
JayblesStang is offline   Reply With Quote
Old 12-02-2013, 02:55 AM   #18
TheWitness's Avatar
I don't think so.
TheWitness is offline   Reply With Quote
Old 12-02-2013, 04:30 AM   #19
Your panties because they will be wet
Old 12-02-2013, 04:46 AM   #20
MidnightBlueGT's Avatar
With
Poop
Old 12-02-2013, 11:22 AM   #21
Lmao thanks. Do you guys think it will look good with my raxiom headlights?
Old 12-02-2013, 01:57 PM   #22
If you get the smoked ones it will. I have the smoked ones also.
Old 12-02-2013, 07:56 PM   #23
huhalbert's Avatar
My foglights aren't the smoked ones but i want them to be smoked. If i bought the foglight tint on american muscle do u think it'll be the same tint as the ones on the smoked raxiom foglights?
Old 12-02-2013, 10:04 PM   #24
It will be a little bit darker. BUT, it will look BA
01:36 AM
