Headers question - Mustang Evolution
Old 12-03-2013, 10:05 AM   #1
Headers question
So I have a 2011 M6 GT with flow master outlaw catback. They come with a mid pipe already, now I'm ready to buy headers, is there any long tube headers that will be a direct fit on the flow masters or will I have to get a header mid pipe combo? I'm trying to save money!
WillyWonka08 is offline   Reply With Quote
Old 12-03-2013, 11:16 AM   #2
Deerslayer's Avatar
You will have to get a mid pipe as well. All long tube headers are longer than your catted H pipe is. I would sugggest just getting an off road X or H pipe. You will gain "ALMOST" as much HP as with LTs, but at a fraction of the price. Install is significantly easier as well and you can run the same over axle pipes and mufflers. You could do a Lethal Off Road X or H pipe for under $400 and DIY
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 12-03-2013, 04:58 PM   #3
Ok cool thanks
Old 12-04-2013, 03:43 PM   #4
BigBry0311's Avatar
get 'em both
I have American racing 1 5/8'' long tubes and their off road X pipe. You will not gain as much power as you think by just adding a different X or H pipe, cause the stock headers are very restrictive. And that is confirmed by the guys at Livernois motorsports. Call them and ask, Those guys really know their ****.
BOSS intake, Steeda CAI, SCT livewire TS, A.R. long tubes & 3" X-pipe, Bassani axle back, AMR wheels, Steeda upper&lower control arms, Raxiom Black Projector/HALO headlights, Trufiber hood, CS/BOSS front & rear valence, BOSS splitter, Stainless Braided Clutch Line, TruCarbon CF Grille, MMD Black tail light trim & Trunk Emblem Surround, Carbon Fiber Dash Overlay Kit. Barton Industries Short Shifter and Bracket, DSS 3.5" Aluminum driveshaft. 417 HP 373 lbsft at wheels and loving it.
BigBry0311 is offline   Reply With Quote
Old 12-04-2013, 05:54 PM   #5
Deerslayer's Avatar
With just the 3" Lethal Off Road X pipe, you will gain around 15rwhp over the stock mid pipe.
You have to tune, so you will gain another 15rwhp on you tune, so all in all from stock to using the 3" Off Road X Pipe, you can gain 30-40 rwhp depending on your tune. This will cost you about $300 and you can easily do it ALL yourself.
Long Tube Headers 30rwhp $800 not counting install, Header mid pipe around $300, so $1,100 not counting install. Just the equipement you could gain 40rwhp and some more with your tune. If you break down the $ per HP, it is a no-brainer. YES YOU WILL GAIN MORE HP WITH LT Headers and a header mid pipe, but the cost is 3x what an Off Road X Pipe costs.
Biggest advantage to the Off Road X Pipe is if you need to revert back to stock, it is a couple of hours MAX, not a full day.
05:37 AM
