shifter suggestions? - Mustang Evolution
Old 12-03-2013, 11:39 AM   #1
SonOfPyro's Avatar
Hi all,
I'm a new member here, great community by the way. I'm wondering if anyone has suggestions for an aftermarket shifter? I've browsed some of the short throws such as the barton, but I'm not a fan of the size. It seems the sit quite a bit lower than stock, which sits pretty low for my comfort any ways. I like the look of some of the taller hurst shifters but can't seem to find the right model, maybe I haven't looked hard enough. Any help would be greatly appreciated. Thanks!
2013 mustang gt
Brembo package
3.73 rear
Manual 6speed
SonOfPyro is offline   Reply With Quote
Old 12-03-2013, 11:41 AM   #2
smbeard's Avatar
MGW all the way man! Put mine in and have loved it ever since. No comfort complaints about the knob placement in relation to the driver either.
smbeard is offline   Reply With Quote
Old 12-03-2013, 11:48 AM   #3
tc x 4's Avatar
Nothing compares to MGW, and there also a mom & pop co.
Old 12-03-2013, 11:52 AM   #4
Must
Get
Wun
KoolPwny is offline   Reply With Quote
Old 12-03-2013, 12:01 PM   #5
Deerslayer's Avatar
MGW.......period
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 12-03-2013, 12:03 PM   #6
SonOfPyro's Avatar
I'm guessing this is the one? Looks and sounds pretty *****en! Thanks for the recommendations, appreciate it a lot.
http://www.mgwltd.com/2011-short_throw_shifter.shtml
Old 12-03-2013, 12:12 PM   #7
Gordito's Avatar
MGW shifter works good on mine as well. It doesn't lock me out of 3rd when driving hard anymore.
Gordito is offline   Reply With Quote
Old 12-03-2013, 12:13 PM   #8
SonOfPyro's Avatar
Is this the one? I'm having trouble replying to this post. But want to thank you all for the replies, thanks!
Old 12-03-2013, 12:22 PM   #9
MidnightBlueGT's Avatar
Mgw.
Old 12-03-2013, 12:30 PM   #10
smbeard's Avatar
Sounds like there's a consensus!
Old 12-03-2013, 12:32 PM   #11
Jayday20's Avatar
Barton shifter and two post bracket I love mine!
Jayday20 is offline   Reply With Quote
Old 12-03-2013, 12:41 PM   #12
SonOfPyro's Avatar
Why cant I reply to my own post
---------- Post added at 12:41 PM ---------- Previous post was at 12:40 PM ----------
Finally... haha
Is this the one?
Thanks all for the suggestions!
Old 12-03-2013, 01:06 PM   #13
Gordito's Avatar
Finally... haha
MT-82 SHORT THROW SHIFTER
Is this the one?
Yes sir!
Old 12-03-2013, 03:32 PM   #14
gtstyles2's Avatar
MGW and Barton are the best shifters for the MT82
---------- Post added at 03:32 PM ---------- Previous post was at 03:29 PM ----------
Barton w/ 2 post bracket*
The main problem with the manual trans is not the short throw itself, but the factory bracket it comes with...
Old 12-03-2013, 03:57 PM   #15
SonOfPyro's Avatar
So, replacing the bracket would also improve things quite a bit?
---------- Post added at 03:57 PM ---------- Previous post was at 03:56 PM ----------
I think I saw that barton sells one separately?
Old 12-03-2013, 04:28 PM   #16
Deerslayer's Avatar
Somewhat with just the bracket. You will get quite a bit more vibration and noise just changing the bracket though.
Old 12-03-2013, 04:30 PM   #17
SonOfPyro's Avatar
Ahh I see. Well, its probably well worth it getting a whole new one. Thanks sir
Old 12-03-2013, 08:32 PM   #18
2011's Avatar
I replaced the bracket with a Barton. Huge difference with little increase in noise and a solid feel going into gear. No more missing 3rd at the drag strip.
2011 is offline   Reply With Quote
Old 12-04-2013, 06:06 AM   #19
I've posted this cpl times regarding the Barton bracket. If u take the bottom of bracket back of, cut a two inch section of bicycle inertube, slide it over the transmission input shaft, then reinstall bracket, it will reduce a lot of the noise. I've had no issues with it slipping on the rubber or anything and the rubber provides an insulator to reduce a lot of the noise transmitted by metal on metal from drivetrain directly into the cabin. Still not back to perfect stock lvl but definite improvement.
Ian13 is offline   Reply With Quote
Old 12-04-2013, 08:55 AM   #20
^^ I may try that. I have the Barton Shifter with 2 post bracket and even though it works great it feels like you're driving a Cement mixer with the drivetrain noise. I will be switching to an MGW but adding some rubber may be worth a shot
Justin81 is offline   Reply With Quote
Old 12-04-2013, 10:14 AM   #21
gtstyles2's Avatar
I had the Barton with 2 post, then went MGW, it's 100% quieter... I do miss the slightly shorter throws from the Barton tho and it was a great shifter. But the shift action is now much more confident on the MGW. Don't over think it, just do it !! U can easily sell the Barton
Old 12-04-2013, 10:18 AM   #22
Luke02GTmustang's Avatar
MGW!!!
Luke02GTmustang is offline   Reply With Quote
Old 12-04-2013, 10:19 AM   #23
WJBertrand's Avatar
When you say transmission input shaft, are you referring to the linkage rod that runs from the shifter to the transmission? Forgive my confusion but input shaft means something else to me with respect to transmissions. Thanks.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 12-04-2013, 10:44 AM   #24
Yea, didn't know the correct term for it
Old 12-04-2013, 10:51 AM   #25
SonOfPyro's Avatar
07:53 PM
