whiteline trans mount - Mustang Evolution
Old 12-06-2013, 03:35 AM   #1
GypsyChris's Avatar
Has anyone installed this transmission mount?, I heard a few good things about it.
GypsyChris is offline   Reply With Quote
Old 12-06-2013, 05:26 AM   #2
NoSlo5oH's Avatar
I have one in my '13 GT and it works pretty good.
NoSlo5oH is offline   Reply With Quote
Old 12-06-2013, 07:39 AM   #3
Missouri Hoss's Avatar
I installed the insert as well. It noticeably helped relieve drivetrain flexing which aided in more reliable shifting. I also installed the Barton 2-post bracket that helped even more. Missed or locked-out shifts are things of the past.
Missouri Hoss is offline   Reply With Quote
Old 12-06-2013, 10:22 AM   #4
Compstall's Avatar
So you're experiencing drivetrain flex again with this part?
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 12-06-2013, 11:14 AM   #5
MR.GT13's Avatar
+1
2013 Mustang GT
Steeda springs, UCA's, LCA's, shifter, bushing, Heavy duty strut mounts, Steeda custom SCT tune, Panhard bar, JHR upgraded clutch line, and white line insert......
MR.GT13 is offline   Reply With Quote
Old 12-06-2013, 11:30 AM   #6
Defiant 5.0's Avatar
I have this part sitting in my living room. I still need to put it on.
2011 Mustang GT 6mt
Mod List: H&R Super Sport Springs, Eibach Camber Bolts, Steeda Panhard Bar, BBK Cold Air Intake, Stack Racing Chrome Strut Tower Bar, Boss 302 Coil Pack Covers, Barton Shifter, Barton 2 Post Bracket, 4.10 Gear, 2013 Track Pack Wheels, QA1 Single Adjustable Rear Shocks, Roush Axle-back exhaust, CDC Chin Spoiler, Saleen Grille,
Defiant 5.0 is offline   Reply With Quote
Old 12-06-2013, 09:24 PM   #7
No. The insert does its job.
Old 12-06-2013, 09:37 PM   #8
Black on Boss's Avatar
It takes like 5 min lol
And I have it as well. It definitely helps. high rpm shift lockout has been reduced, not completely gone but mainly gone
Old 12-12-2013, 10:00 PM   #9
HPFury's Avatar
Blackonboss. Can you post the 5 minute instructions? Or a link? Thanks!
HPFury is offline   Reply With Quote
Old 12-12-2013, 10:19 PM   #10
It's easy. Jack the car up, put on jack stands and put your jack under the trans for support. You then remove the trans support via four bolts, and then slide into place. Lubricant is highly recommended. Once done, remount the plate and you're done.
2011 Mustang GT 6mt
Old 12-13-2013, 04:23 AM   #11
jayman33's Avatar
I run this with a DSS 1pc and an MGW shifter with their harder "track" bushing. I noticeable difference in the amount of flex with high rev engine braking and quick shifts. Some say it added NVH but my car is already too loud to notice anyways.
A boss.....
jayman33 is offline   Reply With Quote
Old 12-14-2013, 01:31 PM   #12
HPFury's Avatar
Thanks Defiant50. Just installed mine. I drilled a hole using a door knob hole drill bit to eliminate the NVH as suggested on many blogs. Sprayed it with white lithium grease and was able to squeeze it in.works as advertised.
Old 12-15-2013, 09:06 AM   #13
I did the same. First time in, I left it as it was and the nvh was a bit much for admittedly pretty sensitive ear. Frankly, making a fully loaded 40K GT car sound like a metal trash can rolling down a hill or massaging my feet to a deep sleep through the pedals isn't on in my world.
Taking a 2-and-a-something inch hole saw I cut through the middle of the lower portion. No change is effectiveness but a big reduction in nvh.
I already have a Steeda bracket on red and a ball style knob so, the stock shifter is as good as it will get and...it feels pretty good.
12:56 AM
